Old 05-15-2020, 08:14 AM   #1
1959 24' Tradewind
Jacksonville , Florida
Need help - how to fix aluminum around wheels 1959 tradewind
I am doing repairs on my 1959 tradewind and havent quite figured out how repair the aluminum around the wheels. Previous owner used aluminum tape to keep it together, but I want a more permanent solution that looks good. I have looked around the Jacksonville, Fl area for someone to assist with the repair, but so far no luck. Any suggestions on how I can fix this or contact for someone in my area that can help?
ID:	367919   Click image for larger version
florida74 is offline   Reply With Quote
Old 05-15-2020, 11:36 AM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Making it look right means replacing those pieces of belly wrap. It's not as involved as it might seem, but you do need the right tools. You drill out the rivets, pull those broken pieces, then cut new pieces to the same size and replace them with shaved Olympic rivets, so the new rivets look like solid bucked rivets.
The "better than tape but not a proper fix" method would be cutting a patch from aluminum and then riveting the patch over the breaks. You'll still see the patches, but it'll look and function better than tape.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
1959, aluminum, exterior, repair, tradewind, wheel
1959 Airstream Tradewind :: 1959 Airstream Tradewind steveirving Airstream Registry Discussions 1 07-27-2021 06:15 PM
Aluminum Airstream Trailer Wheels 15Â*» wheels 6 Lug ArielAirstrm Airstream Classifieds 0 12-22-2019 12:46 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
