Old 06-19-2021, 08:15 PM   #1
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Lower beltline?
Hi
Let me know what this lower trim is supposed to be called?
I picked a short piece to play with before working the back end, I suspect a leak.
Should this be attached with butyl tape? There was none.
What are normal fasteners? It had 5 small pop rivets.
I assume a bead of gray caulk on top when reattached?
Any other advice?
Working on it now, and tomorrow.
Thanks!
ID:	397766   Click image for larger version
Ahroc is offline   Reply With Quote
Old 06-19-2021, 10:01 PM   #2
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Cleaned up!
I used some GooGone, but it left some streaks in the lower wrap. Even though I wiped it off the lower wrap immediately. Used some abrasive hand cleaner GoJo to minimize the streaks but it did dull out the finish a bit.
Still hoping for advice.
Thanks.
Old 06-19-2021, 10:26 PM   #3
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Another question. There is a protusion on the back of the aluminum trim. Is the protrusion supposed to fit in the gap between the two panels? It wasn't originally installed that way, but it seems like it should be.
Thanks again.
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 09:47 AM
bucked rivets at lower beltline: attached to frame? BenHud Ribs, Skins & Rivets 9 02-01-2013 11:00 AM
Looking for Beltline LowellN Clearcoat, Exterior Paint & Trim 17 12-02-2005 08:44 PM
Beltline orange insert replacement tips? Janet H Clearcoat, Exterior Paint & Trim 4 09-27-2004 06:53 PM
Blue Beltline Insert - $13. for 50' roll COArgosy78 Commercial Listings 8 08-09-2003 09:54 PM
