Old 01-13-2023, 08:02 AM   #1
1971 23' Safari
Windsor , South Carolina
Help with rear banana wraps
I am working towards finishing up the belly pan and wraps on my 71 Safari after completely removing the shell and recently joining the frame and shell back together. I thought I had taken photos prior to removal of the banana wraps at the rear ( I had at the front) so I do not have anything to go by.
At the front the wraps go under the skins and I thought it should be the same at the rear but I canít seem to make that fit properly.
Could it be that at the rear they were over the skins and not underneath? Seems that would be a negative towards waterproofing.
Thanks in advance for any information and advice you have.
Ted
Ted
Link to my rebuild page:
https://www.airforums.com/forums/sho...errerid=108723
MTDSilver71 is offline   Reply With Quote
Old 01-13-2023, 05:09 PM   #2
Paradise , Texas
Over is fine. You should also have memory marks on the corner segments indicating such. Just run a thin bead of sealant on top of the seam, under the belt line moulding, it'll work great
Crackerman is offline   Reply With Quote
Old 01-13-2023, 05:26 PM   #3
1971 23' Safari
Awesome! Thank you. I will tackle that tomorrow.
Ted
Rear banana wraps cliffcharb Argosy Motorhomes 2 12-28-2019 08:18 AM
Painted banana wraps LI Pets Belly Pans & Banana Wraps 0 01-14-2007 04:02 PM
Reattaching banana wraps? Mike B Belly Pans & Banana Wraps 2 05-10-2004 04:44 AM
"New" banana wraps j54mark Belly Pans & Banana Wraps 10 10-28-2003 08:36 AM
