Old 05-29-2024, 02:01 PM   #1
2012 27' FB Classic
Gettysburg , Pennsylvania
Fix hole in Belly Wrap on Front Segment
I have been looking all over on the forums for this issue and a possible repair...sorry but can't seem to find one.
I have an approximate 2 inch hole in this lower black plastic section of the segment. See the black electrical tape area temporarily covering it. I am thinking some JB WELD with a fine metal mesh as backer should do the trick.
Can't seem to find what this belly wrap plastic material is, or if anyone has done a similar repair with JB WELD, BONDO, or the like? Appreciate it, and I will happily share pictures of before and after.
Name:	IMG_6698 airstream segment hole.jpg
Buckeye1 is offline   Reply With Quote
Old 05-29-2024, 03:05 PM   #2
1966 22' Safari
Fredericksburg , Texas
Since that belly wrap is black plastic that is UV resistant, I may go to a good auto supply and see if they have kits for vehicle plastic bumper repair. Probably about the same stuff. Plan B: find some UV resistant plastic, make a pattern, install a backer piece adhered to the inside of the wrap and adhere your pattern piece to that. I would use 3M black gasket adhesive for all glued pieces. I really don’t know much about Airstreams built after 1966. Good luck
Bubba L is offline   Reply With Quote
« 2017 Bambi rust? | Top | - »
Using the front side wrap as a template for the rear side wrap haaseome Belly Pans & Banana Wraps 0 10-11-2021 08:32 PM
Rear side wrap template when rear side wrap is missing haaseome Belly Pans & Banana Wraps 0 10-09-2021 01:13 PM
Tuck the side belly wrap under the flat belly pan or the other way around? haaseome Belly Pans & Banana Wraps 4 08-24-2021 11:34 AM
Solar Stone Guards- Wrap / Segment Protectors Ray Eklund Tires 0 04-15-2016 09:29 AM
Segment / Wrap Protector Hinge texascanuk Rock Guards, Segment & Window Protectors 2 06-10-2011 03:15 PM
