No, but a 1/4" one does have rated strengths greater than a 5/32 buck rivet. Even a 3/16 gets close. I know the heads are bigger, but I am fine with that if it keeps me from having to removed the interior skins and cabinets to replace the belly pan.
No one ever said structurally superior. I have used them in the past. Already did a shell off on a 67 and had to use them 2 or 3 places that I could not get a bucking tool. Just wanted to know if they are a suitable replacement if you cannot remove the interior skins. Seems like airstream believes that they are.
I did not know that there are chinese ones out there. I will.order from a gesipa distributor.
Originally Posted by Shermy1987
The point is. A 5/32 Olympic rivet is not structurally superior. When you use one you will see why. Also. If you do choose to go that route. Make sure you buy them from a good supplier. There were shipments of Chinese ones last year that were all junk. I unfortunately brought some as airparts were out of stock.
