Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 11-13-2019, 02:30 PM   #21
1971 27' Overlander
Kansas City , Kansas
Originally Posted by badpaddler View Post
Which I would agree with, but I have no option. Or at least it is not a viable option.
The point is. A 5/32 Olympic rivet is not structurally superior. When you use one you will see why. Also. If you do choose to go that route. Make sure you buy them from a good supplier. There were shipments of Chinese ones last year that were all junk. I unfortunately brought some as airparts were out of stock.
Shermy1987 is offline   Reply With Quote
Old 11-15-2019, 12:28 PM   #22
Everywhere , Minnesota
Thank you to those who have posted their experiences and knowledge to this thread. It helps those of us who might be considered 'newbies' to adequately prepare for unforeseen repairs and so on. Happy trails and adventures.
If you find yourself in a hole, stop digging. Will Rogers
Renascence is offline   Reply With Quote
Old 11-17-2019, 08:59 AM   #23
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
No, but a 1/4" one does have rated strengths greater than a 5/32 buck rivet. Even a 3/16 gets close. I know the heads are bigger, but I am fine with that if it keeps me from having to removed the interior skins and cabinets to replace the belly pan.
No one ever said structurally superior. I have used them in the past. Already did a shell off on a 67 and had to use them 2 or 3 places that I could not get a bucking tool. Just wanted to know if they are a suitable replacement if you cannot remove the interior skins. Seems like airstream believes that they are.
I did not know that there are chinese ones out there. I will.order from a gesipa distributor.
badpaddler is offline   Reply With Quote
Old 11-18-2019, 12:28 AM   #24
2013 27' FB International
Calgary , Alberta
Airstream will replace complete panels and quarter panels with Olympic rivets. Their service department told me it is the most common rivet they use on exterior panel replacement. Due to the number of rivets on a complete panel, they said structurally, we should not see a difference.
danton is offline   Reply With Quote
buck rivets vs olympic rivets Silver Man Exterior Restoration Forum 17 12-17-2021 03:55 PM
Buck Rivets or Olympic Rivets halimer Ribs, Skins & Rivets 5 09-21-2011 03:20 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
