Old 08-19-2023, 01:27 PM   #1
MikeHyland's Avatar
1966 30' Sovereign
Littleton , Colorado
Best way to jack?
After some incredibly generous and helpful time with Aerowood (Kip) Iíve decided to pull the belly pan on my Ď66 sovereign but not remove the frame.
Anyone have any thoughts on jacking it up to facilitate removing the pan with a bit less pain. Any slick ideas to make the job a bit less awkward? Going to be dirty one way or another but why advice would be appreciated.
MikeHyland is offline   Reply With Quote
Old 08-19-2023, 05:09 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Don't worry about easy, worry about safety no matter what it takes. I've dropped and replaced 4 belly pans. It is not a fun job, but quite necessary for a good frame inspection and a good renovation job. I wire brush the frame, I paint the frame, I repair the frame if needed, I install ridged foam under floor insulation, and a rivet up new belly aluminum. It gives me nightmares to think about it.
Using my heavy duty floor jack, I jack on the axle plate or the frame rail just behind the axle plate. I use heavy duty 6 ton jack stands on the frame rails just forward of the entry door on the frame rail, and just aft of the rear axle. Then I do the same thing on the other side, and then back to the curb side. I go up about 3" a try as I don't want to be unstable on the jack stands. I use a creeper while under the trailer, so I want about 20" clearance for doing the work.
Others may have better ideas, but this is what I did. By the way, I like Littleton. Your mainstreet is very neat, like a small town is supposed to be.
David
Name:	1710 Jacked up 2 (Small).JPG
ID:	435756   Click image for larger version
Name:	1710 Axle Mounted 3 (Small).JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Best way to "drive" the 7-way umbilical kittmaster Electrical - Systems, Generators, Batteries & Solar 7 05-14-2019 07:33 AM
Best way to jack up an Aistream 25 ft Mrjkq General Repair Forum 38 01-30-2018 06:46 PM
2 way or 3 way Refrigerator? New or Old? prairieschooner Refrigerators 10 09-13-2006 09:45 AM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
