Old 12-24-2020, 11:32 AM   #1
1969 27' Overlander
Pleasanton , Texas
Belly pan, banana wrap??
69 Overlander
Not sure what the lower panel, below the bottom seam. It seems to be aluminum but is very stout. I have some dents that could likely be removed but sure need some advice.
Mbeech is offline   Reply With Quote
Old 12-24-2020, 01:07 PM   #2
1966 22' Safari
Fredericksburg , Texas
The belly pan was originally aluminum. It’s not unusual to get dents under there due to road debris. Are the dents in the area just below the rub rail on the lower curved edge? Maybe paintless dent repair if they’re visible from 20’. They may pop out with a dent puller, but may be creased. Pictures would help. Good luck
Bubba L is online now   Reply With Quote
Old 12-24-2020, 04:40 PM   #3
1969 27' Overlander
Pleasanton , Texas
Originally Posted by mbeech View Post
69 overlander
not sure what the lower panel, below the bottom seam. It seems to be aluminum but is very stout. I have some dents that could likely be removed but sure need some advice.
Old 12-24-2020, 05:44 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Banana wraps are made from dead soft aluminum and dents are easily removed once they are removed. I've reformed several with my English Wheel. I have a full set here that were in much worse shape then yours.
Old 12-24-2020, 08:51 PM   #5
1969 27' Overlander
Pleasanton , Texas
Thanks. Was hoping I would not need to remove them. Looks like the trim would have to come off.
Old 12-24-2020, 09:00 PM   #6
1966 22' Safari
Absolutely. Try and pull out the dents with the trim in place. Get with Kip (Aerowood) and find out how he does it. Hope it works out. Good luck
Old 12-25-2020, 10:56 AM   #7
2017 22' Sport
Renton , Washington
69 Overlander
If you are ever in the Northwest, reach out to the Dent Whisperer in Puyallup Washington.
They will do you right!
Glampman is offline   Reply With Quote
Banana Wrap + Belly Pan Restoration Obipogue Belly Pans & Banana Wraps 11 08-09-2020 12:49 PM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Belly skin and Banana Wrap Alloy perryg114 Belly Pans & Banana Wraps 16 03-03-2014 05:12 AM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
Belly Pan & Banana Wrap Removal IronGiant Belly Pans & Banana Wraps 2 06-06-2009 08:56 PM
