Old 03-30-2020, 12:41 PM   #1
2016 30' International
redondo beach , California
Trailer Steel Step Holder Broke
Check out the pictures. Anybody have an idea how to fix the steel where the step attaches to the trailer? Thanks!
ID:	364347   Click image for larger version
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 03-30-2020, 01:31 PM   #2
2016 25' Flying Cloud
East Falmouth , Massachusetts
Angry Steps
Same thing here left side for me,Going to add bracket there
200 lbs should be a little thicker
miskeeta is offline   Reply With Quote
Old 03-30-2020, 02:07 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It will need to be welded.
Old 03-30-2020, 02:09 PM   #4
PKI
PKI's Avatar
Walnut Creek , California
https://www.airforums.com/forums/f36...ff-203134.html
The above links to a prior thread. In that thread is a link to another.
Believe with what I see, you need a good welder to reinforce the step area. Some research required as just stronger is not the complete answer. Pat
Old 03-30-2020, 02:19 PM   #5
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Seems like a trip to a welding shop (or a friend with a welder) is on the horizon. It appears that a 3/16 - 1/4 thick metal plate added on top of the channel would help distribute the load. If you have access to the channel across the full width of the step you could add the plate fully from left to right, and several inches beyond on both sides, to give the channel quite a bit more support.
A welding repair shop should be able to make this kind of repair/upgrade. Most RV shops I've been to don't have welding equipment.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 03-30-2020, 05:26 PM   #6
Boxite's Avatar
2008 22' Sport
My first choice repair would also be welding a doubler to the frame and then remounting the steps.
But an alternative would be to:
1- Remove the steps.
2- Use a ball-peen hammer to flatten-out the damaged surface area of frame.
3- Using 5/16” or larger Grade 5 bolts/nuts/washers, drill holes and Attach a 2” piece of angle (steel) about 20” long to the frame such that the entire area is reinforced. The angle can be attached in the central area (between the existing mounting bolts) to the frame. I suggest 3 fasteners in that area. Then, re-mount the steps via holes in the angle at each end.
Old 03-31-2020, 11:32 AM   #7
1976 31' Excella 500
Chappell Hill , Texas
Remove steps. Hammer it back into place, weld cracks. Add long piece of 3/16" or 1/4" steel above frame rail and bolt it through steps on both sides and the frame outward of the step area a little ways. Maybe a 3' x 2" x 1/4" steel bar? You may even get by without welding.
tbashin is offline   Reply With Quote
Old 03-31-2020, 12:00 PM   #8
2012 28' International
Prince Edward County , Ontario
We had the same problem several years ago. An automotive repair shop did a good job of welding a reinforcing plate and reattaching the stairs. It's been problem free since then. Not sure, but the original problem may have been caused by a low speed grounding on the stairs earlier.
Cyclist is offline   Reply With Quote
Old 03-31-2020, 09:37 PM   #9
So we will see how this works. We used two 1 1/4" straps 3/16 thick and drilled some holes to match the existing hole pattern. The new strap just lays down above the existing el cheepo Airstream steel. Then stuck it back together with 3/8 nuts/bolts/ lock washers. A real PIA to get the washers, lockwashers, and nuts all in there above the strap. I don't recommend this method at all.
Stainless Steel Step Upgrade covers step and have edging also # 39771W-04 MTILTON Airstream Classifieds 0 03-29-2020 02:43 PM
Need step light holder for 1991 Excella Classic griffithj Electrical - Systems, Generators, Batteries & Solar 22 11-03-2018 10:36 AM
Step release handle broke due to metal fatigue! How to repair? BentMetal All Argosy Trailers 3 05-24-2015 09:26 PM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
