Old 10-19-2020, 07:54 AM   #21
2019 23' International
Georgetown , Kentucky
Step not locks
Thanks for info on step fixed it from your help
Lcheser is offline   Reply With Quote
Old 10-19-2020, 10:02 AM   #22
2002 34' Classic S/O
sault sainte marie , Michigan
Originally Posted by WizardOfAZ View Post
Duh. I had not inspected closely enough. One of the step screws had backed out from the vibration (photo below) and was preventing completely stowing on the left side. Tightened up, all good now.
Sorry to bother.
Bill
Screws loosening up will continue and need to be checked periodically unless you use some sort of light thread locker. There are also special washers and spring washers that are in the mix. The parts are almost all proprietary as well as pricey, like everything else Airstream. You definitely do not want the step dropping down and hitting something or $$$$$$.
bartzstream2 is offline   Reply With Quote
AI cabinets don't open fully Kjsrbs Airstream Motorhome Forums 2 09-10-2020 03:01 PM
Atlas Steps Stuck in the down position. RGJZ06 Airstream Motorhome Forums 13 06-03-2020 03:54 AM
Steps not properly supported in the extended position chrisnancy Steps 10 11-24-2019 10:19 AM
Repair, don't replace steps DreamStreamr Steps 1 03-17-2013 08:14 PM
