Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 06-09-2019, 10:43 AM   #1
1976 27' Overlander
Milwaukie , Oregon
Step replacement for 76 Overlander
Looks like the previous owner of our trailer must have had an accident at some point and put a different set of steps in. Funny thing is the “new” steps don’t even fit between the outriggers without bending them. I’m attaching photos of the replacement steps and the current outrigger config.
My current outriggers are spaced a little under 22” apart. I see the 20” wide “durable double step” at out of doors mart, which seems like the best option I’ve found online. I don’t really want to spend over $500 for an oem set, and the wife doesn’t want to carry around a step box / platform that’s not actually attached to the trailer.
Given this, would you guys go with the 20” option at out of doors mart? Would you have them welded since the frame is completely exposed? Any other options out there that you guys can recommend?
ID:	342869   Click image for larger version
ID:	342871   Click image for larger version
JoleneAS is offline   Reply With Quote
'65 Caravel dump valve replacement step by step kevinkatz Waste Systems, Tanks & Totes 9 09-04-2020 11:16 AM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
Step by step shell on, front floor replacement '69 Safari thesignlady Repairing/Replacing Floor &/or Frame 31 11-03-2014 11:24 AM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
