Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 04-17-2008, 08:33 AM   #1
'65 Caravel 17'
jlovelady's Avatar
2001 34' Limited
1965 17' Caravel
Lufkin , Texas
Step by Step Repair for 1965 Caravel
I read several posts regarding step repair just prior to damaging the steps on my 1965 Caravel. The step caught a gate post and was bent back at at 20 degrees. Here is how I repaired the steps.
1. I cut the long bolt underneath the step (Caravels have one step) one inch from the left end.
2. Removed the step toward the left after prying out the stud bolts from the sliding grooving.
3. Placed the bent arms in a vice and used a pipe wrench and two large cresent wrenches to slowly straighten the arms to original positions.
(Note: Banging with a hammer will damage the material and cause fractures and not accomplish much.)
4. Used a framing square to align the arms with the sides of the step.
5. Inserted the step on the long rod and pried the arms stud bolts back into the grooves.
6. Welded the rod underneath the step end to end.
7. Made a few alignment adjustments, repainted, and it works fine.
Note: The two main hanging support arms were bent and had to be straightened the same way as the grooved arms.
Good luck on yours.
jlovelady is offline   Reply With Quote
Old 04-17-2008, 09:18 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Great job
I will put this in my Caravel book.
Old 12-19-2009, 02:23 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Russellville , earth
Great information, I need to try fixing mine soon.
Rodney
Visit my photography and painting website
https://rooseveltfineart.com
Instagram is r.w.roosevelt
Boondocker is offline   Reply With Quote
1965, 1965 caravel, caravel
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Need a step for '65 Caravel amron Steps 3 02-14-2007 05:57 PM
step repair smallfry Steps 2 07-22-2003 12:57 PM
Step repair trumpwer Steps 1 03-03-2003 09:44 PM
