Old 07-15-2020, 11:09 PM   #21
2016 19' Flying Cloud
Los Altos , California
spoke to a couple AS dealers. You can order the Thule single step for the Bambi but it's crazy expensive ($350-$450) and you will have to drill new holes in the frame to make it work. To me it's not worth it. I'll just stick with the black steel step that came with my Bambi. I spray-painted over the rust with black paint and looks a bit better. Not nearly as sharp as the new Thule step they use, but it's the best I can do given I just spent over $40k on the trailer..
jsmall01 is offline   Reply With Quote
Old 06-07-2021, 07:57 PM   #22
perri's Avatar
1986 25' Sovereign
1970 27' Overlander
SoCal , USA
My husband installed the Thule step on our 1986 Sovereign. It wasn’t a clean swap, in that it required some minor mods to the steps and to the bodywork. But it was a doable day’s DYI for him. Ordered it for under $200 on eBay from Germany, I believe. It is so much better than that old step—more stable, safer.
perri is offline   Reply With Quote
Step by Step: Replacing OEM skylights with new Custom Maxim Skylights Bambi_Bandit Roof Vents, Skylights & Fans 429 11-11-2020 07:12 AM
'65 Caravel dump valve replacement step by step kevinkatz Waste Systems, Tanks & Totes 9 09-04-2020 11:16 AM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by step shell on, front floor replacement '69 Safari thesignlady Repairing/Replacing Floor &/or Frame 31 11-03-2014 11:24 AM
