Old 03-05-2017, 07:47 PM   #1
Sam and her wheelman Zeke
upnorththree's Avatar
2014 25' FB Flying Cloud
Northern , Illinois
Do I Call a Welder?
Please don't ask because I have no idea how this happened.
We bought our 2014 FC last fall from a private individual. Very nice people but now the verdict is out on their honesty.
We noticed at time of purchase the step was soft, spongy kind of feel and they claimed they had no idea why. Turns out the bolt and washer pulled through the mounting angle iron last week.
It is the bolt closest to the rear of the AS and curbside.
I have removed the step (in perfect condition) and tried to reshape the massive hole left behind by the bolt sheering through the hole.
Everything inside and outside the affected area is plumb and true. No leaks anywhere and door is straight and true (rear entry/exit door).
Suggestions?
Thanks so much.
Popeye
ID:	280915   Click image for larger version
ID:	280917   Click image for larger version
ID:	280919   Click image for larger version
Popeye, Olive Oil, Baby Girl and Little Boy riden' on 20's.
2018 RAM Limited 2500 Diesel 4x4 Crew Cab and RAM boxes
upnorththree is offline   Reply With Quote
Old 03-05-2017, 08:31 PM   #2
Mollysdad's Avatar
I think I'd try a large fender washer first.
I wonder if they backed up into something with the step out?
I'm a large guy and I can't imagine breaking one.
(Reason I always leave the step retracted when storing the RV. or even parking in a WalMart.)
Old 03-05-2017, 08:49 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Certainly a welder could repair that.
Seems to me, tho, that since the frame metal is damaged like it is, the step would also be damaged ..but it is not....
This damage may have been done before they purchased... but not seen by the buyer.. and dealer patched it up... But, you own it now.. just fix it and move on..
A welder can straighten the metal, add 'doubler' to reinforce, drill new hole aligning with the step... rust protect, paint the repaired area... remount the step. The whole area can be protected from sparks, heat...
Let us know!
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-05-2017, 08:54 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Bummer. I wouldn't question the integrity of the folks you bought it from. I'm no structural engineer but in the first pic, the hole where the bolt was ripped out is right next to another hole to its left that looks like it weakens the metal. I'm guessing possible manufacturing defect? Again - I don't know - I just think it can be fixed and you move on to happier camping. Good luck!
Old 03-05-2017, 08:55 PM   #5
PKI
PKI's Avatar
Walnut Creek , California
Looks a bit big to be a normal failure. To have been a collision event, the steps would show damage, unless they are replacements. Betting they are. But what do I know.
1) Contact Airstream and get their recommendation. Likely
a....weld a doubler plate and redrill for step attachment.
or
b....use a rectangular plate as a fender washer - see recommendation above.
or
c.....bolt on a doubler plate u-channel with multiple through bolts.
Good luck with your research. Pat
Old 03-05-2017, 09:23 PM   #6
Granbury , Texas
Glad you didn't get injured coming out and stepping on that!
That repair isn't going to be that difficult or expensive...the cost is in the steps and they look ok.
As others have said...take it to a good welder. They can beef up around that area and drill a new hole and your back in business.
The previous owners don't appear to be at fault here but may need to go on a diet!
cabinetmaker is offline   Reply With Quote
Old 03-05-2017, 09:57 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would straighten the damaged area then "sister" that area on the back side with angle iron and re-drill for attachment of the step. That way you won't have to depend on an area that is already badly damaged.
The area where the inward part of the step is attached should also be strengthened as it is also bent.
You might also look at both of the forward attachment points. They may be ready to give way as well.
It looks to me like there may have been some very heavy loads on those steps.
Get a welder to do that.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 03-06-2017, 09:47 AM   #8
Northern , Illinois
Thanks again.
I wondered the same but, there isn't any sign ANYWHERE of defect or fatigue. It is only that one bolt that sheered through the beam.
The step assembly condition as well as the immediate area is what anyone would expect being two years old with normal highway use. Nothing appears new or abused. Typical rusting and flaking.
Spoke with AS this morning and they are denying any responsibility which is what I would expect. My only concern with AS is, the step assembly angle-iron frame is at least twice the thickness as the "beams" it hangs from. Maybe not a design flaw but certainly foolish.
It truly is strange.
Old 03-06-2017, 09:58 AM   #9
Northern , Illinois
Let us know!
Yes. NOTHING shows any signs of damage. Steps are in perfect condition for two years of age. Even the bolt, washers and slip-nut are in perfect condition.
The buyer (an engineer) was kind enough for the dealer to deliver all the service records (which amounted to 7 or 8 separate service calls) to us.
I'm tossing welder or bolting flat-work behind the damaged area and wanted other input.
Can you tell me what a 'doubler' is?
Thanks.
Popeye
Old 03-06-2017, 10:09 AM   #10
Boxite's Avatar
2008 22' Sport
Originally Posted by upnorththree View Post
... My only concern with AS is, the step assembly angle-iron frame is at least twice the thickness as the "beams" it hangs from. Maybe not a design flaw but certainly foolish.
Those steps are not mfr'd by Airstream... they are made by another mfr'r for a wide variety of applications. The fact that the steel in the steps is thicker gauge than the Airstream attach point is meaningless and not a defect on Airstreams part.
However, it's possible that improper hardware was selected or utilized by the Airstream assembly persons. It may be that a large fender washer was supposed to be installed and missed.
In either case, the unit is beyond the scope of warranty and that is undoubtedly why Airstream declines responsibility... there's simply no way at this point of finding who is at fault. (It could even be the fault of the previous owner or a shop performing work for them.)
Yes, a simple weld repair will take care of this.
Old 03-06-2017, 10:12 AM   #11
PKI
PKI's Avatar
A doubler is a plate or formed structure that transitions loads across a wider area of the original structure. The building industry calls a similar structure a "sister". The logic of such a structure is rooted in the mechanics of replacing the strength of a weakened structure with additional material. Pat
Old 03-06-2017, 10:51 AM   #12
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
It looks like you could use a 6" length of strap steel in the appropriate width and drill and tap a hole in it for the bolt about in the center. Then slip the steel into the frame rail and scootch it back so the hole is in the right place and put the bolt in.
John Woodrow is offline   Reply With Quote
Old 03-06-2017, 12:28 PM   #13
2016 25' Flying Cloud
Holly Springs , Mississippi
Get a Pro Welder
The right way to deal with this "injury" is to seek a specialty house that can Tig weld it. Done correctly, the repair will be nearly invisible. Using fender washers, straps, rods or tubes will be always be unsightly to you and to any future buyer.
My advice is--Get it done right the first time.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 03-06-2017, 12:29 PM   #14
Mollysdad's Avatar
How is the other side attached? It appears to me that the support piece is not thick enough to be tapped and threaded. Since you can get inside the support, I like the idea of a nice heavy bolt and nut. Is that how the right side is attached?
Old 03-06-2017, 03:56 PM   #15
Boxite's Avatar
2008 22' Sport
This is NOT someplace visible. It is BENEATH the trailer. It is out-of-sight and finding a TIG welder is overkill in my opinion. Common MIG (wire-feed) welding is all that's needed for a permanent, good-looking repair. (In fact, an excellent repair be made without welding at all using a doubler, drill, and bolts..., but I like to weld and I'm picky.)
Unless some future owner/worker replaces the stairs... it's unlikely anyone will ever know a repair has been accomplished.
Old 03-06-2017, 05:43 PM   #16
1981 31' Excella II
New Market , Alabama
I agree that welding a thicker piece over the existing piece is the way to go. Was there a stud welded on there or a screw with no way to get to the back side? Airstream loves putting bolt heads where they can only be tightened when the trailer is put together. Looks like it failed in the past and was rigged. I expect the step was hit or overloaded by someone who weighed 500lbs. Welding a new piece in it with studs welded to the plate might make something easier to maintain. I would use a MIG welder on it and call it done then hit it with some black paint.
Perry
Old 03-07-2017, 12:17 AM   #17
Northern , Illinois
Perry
Thanks Perry.
Finished real late tonight before a storm hits. I marked off some very serious steel flatwork and will get someone to drill holes in the appropriate places.
In the mean time, I loaded up a stack of fender washers graduating from real wide to narrow. Real thick. Original bolt. Like a ROCK baby. Wow. Lucked out but, will monitor it closely before I get the welders involved.
It's the craziest thing. Three bolts untouched, no undercarriage damage, not even scratches or dents. All the equipment looks appropriately aged and yet one bolt blew right threw the mounting beam with a major force.
Go figure.
Rick
Old 03-07-2017, 12:37 AM   #18
Northern , Illinois
Not to kick a dead horse but, the steps and step assembly are in perfect condition. Like I just took them down from a shelf at the store.
I hope I didn't mislead that the step assembly was an issue. AS attached these highly engineered, heavy duty, thick steps to house-gutter-thickness metal beam. NOTHING is wrong with the steps whatsoever. The up/down travel of the steps glide. For that matter the bolt, washer, and snap nut survived perfectly after it sheered through the mounting point.
In any case all four corner mounting points had the identical anchoring materials. It's just Twigh Light Zone goofy.
Anyway, I used graduated fender and lock washers, reused the same bolt and Wham, I am in business. Solid like a rock.
I'll monitor it very closely before I call in the welders.
Thanks for your response.
Rick
Old 03-07-2017, 11:59 AM   #19
Boxite's Avatar
2008 22' Sport
Rick
You may never need to do anything further at all...not even welding.
Old 03-07-2017, 01:21 PM   #20
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our step mounting metal began to deform the same way. We were at Airstream Factory Service Center in Jackson Center and we asked them about it.
Fairly common, they removed the step assembly, welded a piece of square steel tube (maybe 1" x 1") the width of the step assembly up behind the mounting points to reinforce it, painted it and bolted the step assembly back in place.
Doug and Cheryl
Stud Welder The Flintstones Ribs, Skins & Rivets 11 04-24-2009 04:27 PM
Which welder do I need? Bob Thompson Ribs, Skins & Rivets 9 04-22-2007 09:25 PM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
sunday fun with the welder! john hd Hitches, Couplers & Balls 19 07-30-2006 09:50 PM
Going to the welder Bobolo Repairing/Replacing Floor &/or Frame 23 07-14-2005 10:57 PM
