Old 07-24-2017, 03:50 PM   #1
blickcd's Avatar
Milford , Ohio
Anyone sell a rebuild kit for the steps?
Its just another project that would be nice to get done. Seems to me that at one time you could buy a kit that had all the various screws and washers in it, but a search now turns up nothing.
I know that some places like Inland RV have all the various pieces, but it would just be nice to get a package deal, and maybe some instructions in case I forget how I took them apart.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 07-24-2017, 05:07 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Out of Doors Mart sells all of the parts. Some are pkgd as a kit. They also have assembly pics on the website.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 07-24-2017, 06:57 PM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Yes I think it was out of doors mart where I saw the packaged kits, my lower step is Missing the correct hardware and for $50 I can get the needed 2 bolts, 2 nuts and a couple washers.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-31-2017, 10:22 AM   #4
blickcd's Avatar
Milford , Ohio
In looking at my steps some more, checking for sloppy bolts, etc, it seems the problem is in the top step. The notches at the front corners where the supports for the lower step rest, have just worn too deep over the years.
I could replace that top step at considerable expense, or just mig weld some infill, grind and file to perfect fit. I think the welding will be the cheaper and easier way to go.
Christopher
Old 07-31-2017, 11:17 AM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My steps were very sloppy and drooping a bit from loose fasteners. Sooo I drilled out each rivet connector to the next size bigger, then replaced all the rivets with stainless machine bolts and self locking nuts. It helped a great deal. I couldn't get to a couple of the higher rivet with a drill but I was able to get to most of them. No more droop, feel much better, look much better when deployed.
mayco is offline   Reply With Quote
Old 08-23-2017, 04:57 PM   #6
blickcd's Avatar
Milford , Ohio
Here is an update. I purchased all the bolts needed for 8 pivot joints. That would be 4 each side, connecting the bottom step to the top step, from Out Of Doors Mart. I also got replacement stick-on non-slip pads.
These might be the most expensive bolts I've ever purchased as the total order came out to around $150 with shipping.
While some slop is gone and the bottom step might be improved a little, there is still a noticeable droop. Note that the top step is level so only the pivot bolts at the front edge which connect the arms for the lower step were replaced.
A lot of money for not much results, though the non-slip pads are really great.
I think the notches on the top step are a bit worn down and that is the problem. Not sure if the steps are a grade of aluminum that can be welded.
Mayco, I need a better explanation of the repair you did, as I think all the step parts are bolted and not riveted. If rivets are used on the upper step, up under the trailer someplace, that may not help anyway. As I said, my top step sits level and firm. Just the bottom step tilted maybe 5-10 degrees down.
Christopher
Water Pump Rebuild Kit DancingGoat Plumbing - Systems & Fixtures 2 02-13-2015 10:55 AM
Hitch Latch Rebuild Kit? kry226 Hitches, Couplers & Balls 24 03-09-2013 07:47 PM
AquaJet ES water pump rebuild kit? Wingeezer Water Heaters, Filters & Pumps 3 06-03-2011 01:15 PM
To sell or not to Sell ?? osolow Dollars & Cents 5 05-04-2009 01:39 PM
rebuild kit for water pump 76 sovereign chris's 67 Fresh Water Systems 2 03-06-2007 08:18 PM
