Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 04-29-2021, 06:12 AM   #1
2017 23' Flying Cloud
Waukesha , Wisconsin
Aluminum step problem
In mid-December 2020 we relocated from Oregon to Wisconsin, traveling through winter driving conditions. Although it was washed, our 2017 FC 23FB sat unused over the winter. The fold out step release from under the trailer, but when I tried to fold out the lower step it is 'corroded' in place, I think due to ice-melt and sand enroute. I've used a combination of a rubber mallet, WD-40, and silicon to finally unfold completely. However the hinge points are still semi-frozen. It looks like the way to fix this is to take the hinges apart, but I'm not sure what procedure to use. Does anyone have experience with this or can recommend a site that explains this? Thank you.
ibosket is offline   Reply With Quote
Old 04-29-2021, 02:14 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ibosket,
I’m looking at my aluminum steps right now.
Not sure I’d take it completely apart to free it up.
A good set of Allen wrenches, favorite corrosion spray. PB Blaster, Kroil etc.
Loosen one fastener at a time. Flush crud out move to opposite side and repeat. Working one joint at a time. Then consider getting a joint completely apart and clean real good.
Pics first of how it was.
This is some custom hardware Allen wrench on both ends in some places.
Patience.
Gary
GCinSC2 is offline   Reply With Quote
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
