05-31-2020, 04:49 PM
1963 22' Safari
mcallen
What is this trim called?
Hello, I am wanting to replace the brown rubber trim just above the silver trim, can someone please tell me the name so i can look for it. Oh and one more thing, where can i find parts for a 1963 safari airstream, seems like everywhere i go they start from 1964 or 1966 and up.
Please if you know of a place let me know. Thank you in advance.
05-31-2020, 05:22 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard 👍
It does not look Airstream...our '63 Safari had no such molding.
"You don't know where you've been until you leave, enjoy life" RLC
05-31-2020, 06:45 PM
Retired.
, At Large
That's a non-OEM part, a previous owner modification.
06-01-2020, 10:00 PM
1963 22' Safari
mcallen
Hello Robert Cross, the picture you have is the front trim, which is different from the back. As you can see in the next picture of my front part of the trailer my trim looks just like yours. Now the back trim is different.
06-01-2020, 10:02 PM
1963 22' Safari
mcallen
Overlander63, thank you for your response, i guess we can just pull it out since it might not even belong there. Thank you for taking the time to response to my question.
06-01-2020, 11:48 PM
1967 22' Safari
MILAN
Non-OEM Moulding
garciacag, I think that this Orange moulding was a previous owners way of dealing with a leaky beltline trim strip. If you remove the aluminum beltline by drilling out the pop rivets that secure it to your coach you will find the seam between the aluminum side panels and the belly (banana wraps) skins that help with water intrusion at that seam. Once removed you can get that orange colored plastic moulding off the trailer and re-install the beltline trim strips. To do this the best way I would recommend using Captain Tolleys Creeping Crack Cure. It is available from most boat supply shops or Marine dealers. Use it to seal the seams between the Aluminum side panels and banana wraps. It can also help seal any riveted seams! Just keep applying it until it no longer draws itself into the seams, then caulk the seams as you normally would. When you re-attach the beltline trim use the same process after the pop rivets are installed (butter each rivet hole with caulk and each pop rivet as you re-install them) then use the Captain Tolleys on the upper edge of the trim strip and finally caulk the upper edge of the aluminum trim strip. The last thing to get the original look back to the trim is to install Airstream Blue insert trim stripe (nosing I think it is called) into the trim strip. If done this way this should insure that you will eliminate a area where water can get to your sub-floor plywood and cause lots of damage that is hard to find until it is too late! Hope this helps, Ed
Edit..... Pop rivets should be used on the beltline trim aluminum as the fit flatter than Olympic rivets do in this area. BUT.... Be sure to use Captain Tolleys and caulk on the hole where the pop rivet pin come thru the rivet to seal that hole too! Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
