Old 06-13-2019, 07:42 AM   #41
"Cloudsplitter"
Originally Posted by BigHornStream View Post
My problem is removing the bug tar and road grime in doing the wash/prep especially after this last road trip. I have used Meguiar's Gold Class Wash and Turtle Wax Max Power and even with lots of elbow grease I can't seem to get it all off. I Walbernized just before the trip thinking it would be easier to clean but not so. What do others recommend for bug tar removal? I plan to try either Griot's or Glare to seal it next time once I get it clean.
WD40...spray, wait a bit & wipe. Heavy tar..Brakleen
Old 06-13-2019, 08:50 AM   #42
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I have painted the trim on our '72, but it gets dinged easily on the rock guards. I end up touching it up at least once a summer. Any ideas on how to protect it? We have Walbernized last summer. I was thinking about spray clear coat....
Kay
Old 06-13-2019, 09:12 AM   #43
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I Walbernize once a year, even though water still beads. I find it easy to use and long lasting..
2019 Ford Expedition Platinum
Old 06-13-2019, 09:40 AM   #44
2018 19' Flying Cloud
Newport , Washington
Originally Posted by vintagemotor View Post
Use only Walbernizer!! The coating that Alcoa applies is called "plasticoat" it is nothing like automotive clear coat and only Walbernizer will maintain its appearance. Using Automotive wax products will speed up the deterioration process and you will have transparent flaking like we have seen on other posts here........
Slightly off topic but if the Alcoa coating is this fragile then should we also be concerned about what we use to clean the interior surfaces if they are aluminum? Mine need cleaning and I was going to use glass cleaner as other have suggested but would really be upset if this led to flaking.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 06-13-2019, 11:29 AM   #45
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
For the inside panels I have found that a damp fibre cloth is all that is normally needed.
thewarden is offline   Reply With Quote
Old 06-13-2019, 11:44 AM   #46
"Cloudsplitter"
Kay
3M makes it also..
Old 06-13-2019, 02:07 PM   #47
Wconley's Avatar
2018 28' International
Renton , Washington
I used Walbernize for the first time the last two days after completing a 16,000 mile trip. Previously I have used regular auto wax and while we were traveling I used Griots or McQuires spray wax for their convenience. I’m pleased with how easy it is to apply and buff off but I was surprised by how liquidy it is and how quickly it separates requiring constant shaking. Now to see if it lasts any longer than the spray waxes.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 06-13-2019, 03:29 PM   #48
2005 22' International CCD
Buckhorn , Ontario
I have used walbernize since I have owned my trailer. Once the Spring crap like poplar tails, yellow pollen and maple tree helicopters stop. She gets a thorough wash. Then a full walbernize. Top to bottom. She stays clean and shiny right the way through summer and winter. Good rains clean off dust and dirt and water beads nicely. It is a proven product when applied correctly. It takes time and elbow grease but well worth it.
I have always used WD40 for any sap, grease or road tar that makes its way on to my skin. Never had an issue with my clear coat other than the renounce corrosion around marker lights and small dings. That will be a job down the road to have it all treated at once.
05ModPod is offline   Reply With Quote
Old 06-14-2019, 08:23 AM   #49
BigHornStream's Avatar
2017 25' Flying Cloud
Sheridan , Wyoming
Good to know about WD40 and Brackleen, thanks for these know-hows, much appreciated. Now I'm ready for some serious waxing.
BigHornStream is offline   Reply With Quote
Old 10-04-2019, 03:47 PM   #50
2018 23' Flying Cloud
St. Petersburg , Florida
First off, thank y'all for all the varying responses. Again, like everything else I've read about from tires to cleaning and waxing, there are nearly infinite opinions. I'm too ignorant to offer one.
I think I've learned that it's better to do something toward cleaning than to do nothing -- unless, of course, I do the wrong thing, then I'm in deep poop.
DavidaPeter is offline   Reply With Quote
Old 11-27-2019, 08:26 AM   #51
2019 28' International
Silver Springs , FL
Walbernizer is the ticket . It works great on the towe vehicle as well especially glass .
Blue Coral soap from Walmart works very well . I use a soap cannon to apply the soap in even patterns from top to bottom . Rinses very clean with no streaks .
You can never over wax a unit . The manual does state to wash the unit every 4 weeks and wax at least twice a year .
The most you can do is keep the unit protected.
Don't fall into Ecopro or any BS protection plans as I did with our prior unit .
Upon 3 factory tours I've witnessed the employees applying Walbernize to each completed unit .
Viniger and water is used to remove any water spots first after the hurricane chamber.
Tommy Black is offline   Reply With Quote
Old 11-27-2019, 09:26 AM   #52
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Adjunct post: Griots clay mitt
For my once-a-year wash and wax marathon I use Griotts Clay Mitt and soapy water instead of actual clay to get the surface really clean and smooth prior to waxing (or whatever). With clay you wash, then clay, then wax. This eliminates a step and does a great job.
brad1 is offline   Reply With Quote
Silicone spray instead of walbernize??? munimula Cleaning, Stripping & Polishing 18 11-13-2023 06:48 AM
Waxes, Corrision X, Boeshield T9 PSU1981 Exterior Restoration Forum 0 06-23-2016 11:55 AM
to Walbernize or not to Walbernize Lumatic Cleaning, Stripping & Polishing 29 05-17-2015 06:56 AM
Cleaning off salt spray, S CA HeadWest On The Road... 2 01-26-2015 12:16 PM
How to clean road salt and spray off underbody of AS? Whirlaway Winterizing, Storage, Carports & Covers 5 01-14-2009 06:39 AM
