The dreaded
Looked at our FC 30 ft 2021 trailer out in the sun and said hmmm what’s this ? sealer running or a scratch?
Not a scratch won’t rub out removed the black tank flush cover two screws and oh no the dreaded Fil corrosion.
It started at the screw hole. I cleaned the area with wd40 then put a corrosion fluid film brush on coating over the saw cut out and screw holes. . Took pictures sent them to JC as it still under warranty.
Our trailer is stored inside and treated with Glare but no wax or ceramic can get under a fitting.
Your suggestions? I don’t want it spreading. We have a JC appointment in the spring. Sorry for the tilted pic I give up on iPhone to Forum transfer
