Old 10-27-2011, 08:22 AM   #1
1981 31' Excella II
New Market , Alabama
Removing the WBCC letter without doing damage to clear coat
I was wondering if anyone has a techique for removing the red letters from the front and rear of the end caps. I know I could use stripper on them but I would rather not strip what is left of my clear coat.
Perry
Old 10-27-2011, 08:24 AM   #2
Perry
Place a wet towel over the numbers and then apply heat to the towel from an ordinary "iron".
That will soften the adhesive so that you can simply pull the numbers off.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2011, 08:44 AM   #3
1981 31' Excella II
I will try that Andy. Mine are cracked and starting to peel but it comes off in little flakes.
Perry
Old 10-27-2011, 08:46 AM   #4
Perry
The steam-off method has yet to fail, over the past 40 years.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2011, 09:07 AM   #5
timmaah's Avatar
1999 25' Safari
On , the road
Eraser Wheel
You will be amazed at how easy it comes off. No damage to clearcoat at all.
Amazon.com: AES Industries 4" Smart Eraser Pad with Drill Adaptor Arbor: Automotive
timmaah is offline   Reply With Quote
Old 10-27-2011, 10:13 AM   #6
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I used a hair dryer to heat the numbers, then some elbow grease. They came off clean with a little bit of effort. Andy's idea sounds easier.
c_lewis77 is offline   Reply With Quote
Old 10-27-2011, 10:26 AM   #7
Naper's Avatar
2017 30' Classic
Loretto , Ontario
WD40 works great removing any remaining glue
Naper is offline   Reply With Quote
Old 10-27-2011, 11:45 AM   #8
1981 31' Excella II
Sounds like a plan. Thanks for all the advice. I have used the same method with a wet towel to steam dents out of wood.
Perry
Taking Scratches out of the clear coat any ideas ksp2822 Clearcoat, Exterior Paint & Trim 3 09-28-2011 12:39 PM
Looking for clear coat refinishing wilkes711 Clearcoat, Exterior Paint & Trim 0 09-14-2011 11:59 PM
Clear coat on '63? esmaytum Clearcoat, Exterior Paint & Trim 2 07-28-2011 06:59 PM
what clear coat product available deelind Ribs, Skins & Rivets 0 07-24-2011 05:54 PM
Living with peeling clear coat? timmaah Clearcoat, Exterior Paint & Trim 14 04-26-2011 09:20 PM
