01-09-2017, 02:24 PM
1988 34' Excella
Peachtree Corners
, Georgia
Paint for water heater cover
Just purchased a Girard on demand water heater after realizing none of the water heater manufacturers offer a brushed aluminum door to match airstream finish. The door I have is "Polar White". What is the preferred method to paint to match the exterior? I was thinking I could try spray paint first, and if that looks bad, get quotes from an automobile paint shop.
If spray paint can work, what is the preferred brand/color? Should a clear coat be applied on top of the paint?
Thanks. There does not seem to be much information out there on this topic.
01-09-2017, 02:42 PM
1955 22' Safari
Laredo
Rustoleum
I used this with good results.
https://www.rustoleum.com/product-ca...c-spray-paint/
Fairly soft (typical for rattle can paint) but looks good after a year as long as you don't scratch it.
01-09-2017, 02:51 PM
1988 34' Excella
Peachtree Corners
, Georgia
Originally Posted by BambiTex
Titanium Silver I suppose (vs satin nickel)? That still looks pretty good. I don't have a polished exterior but I think I am overthinking this whole thing. I think I'm just going to pick one from home depot and see what happens.
01-09-2017, 03:47 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Alan
01-09-2017, 05:14 PM
1993 34' Excella
Estancia
, New Mexico
There is a paint called Liquid Stainless Steel. Never used it, but it sounds good.
01-09-2017, 06:00 PM
2005 30' Classic
Burlington
, Ontario
I used liquid stainless steel on door hinges and battery bx surrounds a few years ago - they were badly corroded.
I still have quite a bit left in brush form, plus a small spray can, and have been thinking about trying in on the appliance covers that do need painting. Not sure if heat might be a problem though.
It comes with a clear coat, and was meant to convert kitchen appliances to "stainless" look.
Before using it on the AS, I asked them if it was ok for outdoor use and they said it would be ok -it has been for several years.
https://www.amazon.ca/Liquid-Stainle...tainless+steel
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-09-2017, 06:07 PM
Airstream - Other
Bosque Farms
, New Mexico
Go to an automotive store and buy a can of high temperature paint in whatever color you want.
Lynn
ACI Big Red Number 21043
01-09-2017, 06:52 PM
2016 28' Flying Cloud
Brandenburg
, Kentucky
Paint
I used VHT spray paint on my previous AS. I picked it up at the local autoparts store. It comes in various temperature ranges and blended well with the AS.
01-10-2017, 05:52 AM
1955 22' Safari
Laredo
Yes
Titanium silver. Mine has held up well with no noticeable effect from the heat.
01-10-2017, 11:12 AM
Pearland
Krylon "Dull Aluminum" #1403 is what I used on my Fridge vent door on my Avion. Not sure how it would hold up to heat though.
Dale
1983 34V Avion
01-10-2017, 01:56 PM
2001 25' Safari
Ridgefield
Originally Posted by A W Warn
Ditto. Used this on my water heater and furnace covers. Looks great! Big improvement over the original painted covers.
01-10-2017, 02:10 PM
1966 26' Overlander
2012 28' Flying Cloud
Waukesha
, Wisconsin
I used the Rustolem on my water heater cover and it's worked out fine for a full season.
01-10-2017, 02:41 PM
Silver Spud
1975 31' Sovereign
Twin Falls
, Idaho
When I upgraded my water heater it came with a white door. I scuffed the white and spray painted four light coats of rust oleum spray paint. Aluminum was the color and I did not use high heat nor a clear coat. It matched the exterior almost perfectly with less than a half shade off. It has been on, successfully without any change, for five years now.
01-10-2017, 03:40 PM
Airstream - Other
Bosque Farms
, New Mexico
Personally, I would not get in too much of a tizzy about high temp paint. Yes, I used it, but plenty of others have eschewed its use. And they're still alive and posting.
Lynn
2012 30' Flying Cloud
San Antonio
Great match. I use this to spot repair the skin where I've fixed filiform areas.
01-10-2017, 03:42 PM
San Antonio
The above Rust-oleum avail at Home Depot.
01-10-2017, 05:48 PM
2005 30' Classic
Burlington
, Ontario
Great tip, thanks, I will try this on my covers next month when we get down south!
Also interested to try with filiform repairs, I have tried several paints and never found a close match, so I have just been scraping off the corrosion and then using clear coat on its own.
Brian.
2005 Classic 30'
01-10-2017, 05:50 PM
2005 30' Classic
Burlington
, Ontario
Also interested to try with filiform repairs, I have tried several paints and never found a close math so I have just been scraping off the corrosion and using clear coat on its own - doesn't look the greatest but better than the whitish filiform.
Brian.
2005 Classic 30'
01-10-2017, 06:19 PM
2013 30' Flying Cloud
Greenwood Village
Only other thing I did was use a little sandpaper to scuff up the cover so the paint sticks better and less peel chance. Also clean of any oils and you should not have any issues
01-11-2017, 08:12 AM
San Antonio
http://www.airforums.com/forums/f142...ml#post1726310
Brian, here is a little info on what I do with the skin filiform.. match is not perfect, but much better than the corrosion unless a small area.
