Old 08-07-2020, 01:14 AM   #1
2007 19' Safari SE
Gig Harbor , WA
Oxidation/Corrosion around taillights
We just bought our first AS, 2007 Safari SE 19'. I was spending some time cleaning it today and there are a couple spots of corrosion which I wanted to ask to see the best way to tackle it. Or is it better to leave it alone? Any help would be appreciated. Thanks.
ID:	375093   Click image for larger version
seattleym is offline   Reply With Quote
Old 08-07-2020, 01:46 AM   #2
2007 19' Safari SE
Gig Harbor , WA
Posted this too soon. Just did some reading on the forum and I think my best bet will be to remove them, sand the clear coat off and get the corrosion off and finish by re-spraying a clear coat.
Old 08-07-2020, 06:34 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Good plan...all but the re-spraying.
I did the battery frames for the "Cloudsplitter".
Got them to pretty well match the AS panels, then lightly polish with 3M Aluminum polish when needed. Finally a light wax.
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 08-07-2020, 10:04 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Nyalic over cleaned spot.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-08-2020, 11:16 AM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Eight years ago we had a local auto paint shop (through Vinnie) clean, prime and paint our rear tail light pods, furnace plate and hot water heater plate with a metallic grey to match the aluminum around it. We have a 2008 27FB. I replaced the chrome eyebrows on the tail lights at the time which look like they are pitting a little. Pictures for from this morning (8 Aug, 2020). - Brad
Name:	Aluminum Parts Paint - 1.jpg
ID:	375216   Click image for larger version
Name:	Aluminum Parts Paint - 2.jpg
Name:	Aluminum Parts Paint - 3.jpg
ID:	375218   Click image for larger version
Name:	Aluminum Parts Paint - 4.jpg
SuperTrouper is offline   Reply With Quote
Old 10-12-2020, 03:43 PM   #6
Rot-Roo Rastro!!
silversled's Avatar
2014 30' Classic
Metal Analysis on Tear Drop Fixture
Sorry if this is considered changing the topic but I hope it is related...
We recently had to replace our trailering lights because they were out. This particular model year the tear drop trailering lights are seated in an aluminum bezel and then secured to the trailer. On replacement, a few had the white corrosion Filiform. Like many threads mention, there is a little chemical reaction going on. So I took the bezel in for analysis to see what was contributing to my problem. Here are the results: 99.4% Aluminum, 0.0208% Manganese and 0.038 % Iron. And there is the ugly truth, especially when you add water.
After treatment, we slipped a “plastic washer” between the trailer and the bezel and re-secured. Yes, that is a plastic water bottle converted to an Airstream anti-corrosion “washer.” Time will tell if it works.
ID:	380703   Click image for larger version
Barry & Andrea
2014 Airstream Limited 30' ~ Silversled
2019 Chevy HD2500, 4X4, Crew Cab
AIR #12075
silversled is offline   Reply With Quote
Old 11-10-2020, 04:10 PM   #7
St.Francisville , Louisiana
Excellent idea!
La3rdworld is offline   Reply With Quote
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 33 06-29-2021 10:19 AM
Heavy Oxidation Around Exterior Light jrjackson Cleaning, Stripping & Polishing 0 09-11-2015 12:45 PM
I'm not a smart man, Jenny... but I know what oxidation/corrosion is. Taylormade Cleaning, Stripping & Polishing 4 11-19-2013 09:43 PM
Corrosion around hinges and rivets ilittle Ribs, Skins & Rivets 3 10-14-2009 06:46 PM
Does oxidation cause oxidation bmklawt Ribs, Skins & Rivets 9 02-09-2009 09:21 AM
