Old 05-07-2020, 07:17 PM   #1
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Original A frame color, 1994 Excella 1000
I have removed as much rust as possible from the A frame, painted with 2 coats of POR15, and now want to repaint the original color. What was the original color? Was it black or the same grey as the banana wrap? The Barker jack was the same grey as the wrap. Trailer is a 1994 Excella 1000, 34 ft. I am sure the A frame was repainted by a PO prior to purchase by me. Thank you.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-08-2020, 07:19 AM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Some early to mid 90's have the stainless steel wraps to protect the frame from towing equipment. The color I found under those wraps on several early 90's was the same as the banana wraps
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 05-08-2020, 08:36 AM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Thanks Peter! I too have the stainless wraps, and it's impossible to tell what the original color was. I suspect that the frame was painted a couple of times in the past by PO. I found some Rustoleum Charcoal Grey that looks very close to the bananna wrap and will repaint everything, including the banana wrap with that. I found that the POR15 works very well to stop the rust problem. Thanks again. Chris
ACI #7394
Hensley Hitch
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 9 08-07-2020 01:37 AM
Color temperature and color rendition index of fluorescent tubes Jammer Lights - Interior & Exterior 3 08-16-2010 09:29 PM
1994 Airstream classic Excella 1000-34 ft eBay Watch Airstreams on eBay 0 03-25-2009 03:40 AM
