Old 02-08-2023, 09:00 AM   #1
2018 27' International
San Antonio , Texas
Name Badge Removal
I have purchased a 2018 International Signature and the previous owner placed their Name Badge on the outer skin right next to the door. As I have renamed the trailer, I need to remove this badge. Any advice on how to get the adhesive to release so as not to mar the outer skin. I did several searches and cannot find a thread for this although I realize this cannot be the first question about this....any help would be appreciated.
JGF79 is offline   Reply With Quote
Old 02-08-2023, 09:57 AM   #2
Little falls , New York
Something sharp edged and plastic? Probably the only way to not see the inevitable black leftover goo is an even bigger badge.
I’d probably try a little solvent of some sort but I wouldn’t suggest that to others. Probably wouldn’t end well plastic coating and all.
civeng99 is offline   Reply With Quote
Old 02-08-2023, 10:00 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Careful use of dental floss can often be used to break the bond between the adhesive tape and the surface. You'll likely have to do some clean up with some type of solvent, but test the solvent first in an area not visible to make sure it doesn't remove/damage the clear coat.
Richard
11018
richard5933 is offline   Reply With Quote
Old 02-08-2023, 10:02 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Fishing line can also be used...
Richard
Old 02-08-2023, 10:07 AM   #5
That’s a great idea..
Old 02-08-2023, 10:23 AM   #6
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
A heat gun to soften it can help but be careful not to get it too hot, I have successfully used a heat gun and plastic razor blades to remover stickers on fiberglass but not on aluminum that has a protective coating so use extreme caution with the heat. Amazon sells plastic razor blades.
I also used 3M adhesive remover but again you should first test this on your Airstream.
Brian
ITSNO60 is offline   Reply With Quote
Old 02-08-2023, 10:51 AM   #7
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
I used a plastic razor blade to remove the big stickers installed by the original selling dealer, then I cleaned up the goo with Bug and Tar remover. Worked great.
10Smiles is offline   Reply With Quote
Old 02-08-2023, 11:37 AM   #8
Jeff7176's Avatar
2018 25' International
Full-time , Traveler
I have had success in the past by waiting for a nice, sunny, preferably warm day (depending on where you are, this may not be realistic currently) and once the badge needing removal starts to twist a little, either take some fishing line behind the emblem to “slice” it off the glue, or if the emblem twists pretty freely, I just keep gently twisting. Be careful not to lift it from one edge as it could very likely leave a scratch/mark. This keeps you safe from adding too much heat to a small area.
After the emblem is gone, I work at rubbing as much glue off by rubbing it with my thumb, and the use some bug and tar remover if needed.
Jeff7176 is offline   Reply With Quote
Old 02-08-2023, 12:52 PM   #9
Boxite's Avatar
2008 22' Safari
Especially strong is the woven polyester fishline…rather than monofilament.
Old 02-08-2023, 01:33 PM   #10
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Steam clothes iron and plastic razor blade. Try WD-40 or possibly denatured alcohol as a solvent on the left over adhesive.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 02-08-2023, 01:37 PM   #11
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
X2 on the WD-40 or bug and tar remover which is usually diesel or kerosene for the glue.
JEWare
John Ware is offline   Reply With Quote
Old 02-08-2023, 02:47 PM   #12
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
The fishing line works, then use duck tape to remove left over adhesive.
- Stewart
s1000pre is offline   Reply With Quote
Old 02-08-2023, 08:18 PM   #13
1994 30' Excella
Mississauga , Ontario
`or you could install your new one on top of the existing one. Just a thought.
Al and Jean
TAC ON-3
Old 02-09-2023, 06:53 AM   #14
"Cloudsplitter"
As noted... fishing line. 10lb and above.
I've used Brakleen & WD40 to de-goop the panels.
Old 02-10-2023, 02:30 PM   #15
San Antonio , Texas
Thank you!
All of your replies most useful! The fishing line idea is awesome!....never would have thought of that...
Thanks to all of you for taking the time to give great advice!
Old 02-15-2023, 09:41 AM   #16
PatSoozy's Avatar
2022 25' Globetrotter
Bellevue and San Antonio , Nebraska and Texas
Citri Solve
Had good results with this taking the residue off from our BRNs when we sold our previous units. Do test it first though and use a light touch.
PatSoozy is offline   Reply With Quote
Old 02-15-2023, 03:37 PM   #17
Marietta , Arizona
Why remove. Why break the bond? Why expose bare aluminum?
Put you name or any graphic OVER the unwanted one.
If the unwanted name has relief/depth, just reduce that to a flat surface.
Suggestions:
Peterbilt
Wile E Coyote
Wall E Byam
You first wife’s name
Winnebago
Keep ‘em guessing
MonacoJay is offline   Reply With Quote
where to stick my official name badge? Roguegaston 2005 and newer - Bambi all models 91 02-15-2023 08:23 AM
Name Registry Badge Location tgilton Sprinter and B-van Forum 13 07-14-2020 07:44 PM
Need Help - Airstream Name Badge STstudios Airstream Motorhome Forums 10 08-24-2019 08:19 PM
Excella name plate/badge lahrfarm Exterior Restoration Forum 9 07-31-2015 03:46 PM
