03-17-2021, 03:10 PM
2014 25' International
CMCH
, New Jersey
Exterior Frame Paint Color
Has anyone had paint mixed that matches the original gray, Have a 2014 International 25 looking to do some touch ups....cost of buying it in a spray can is nuts. If so please provide the mixture or photo of label. Thanks.
03-17-2021, 03:17 PM
2016 23' International
Los Angeles
Here are the goods
https://woodlandairstreamparts.com/products/touch-spray-paint
03-18-2021, 05:57 AM
CMCH
, New Jersey
Thanks, I was looking to have a quart mixed at the local auto parts store, Looking for the recipe thought someone who has done a restoration might have it.
05-21-2021, 05:06 PM
2011 International 684
Galway Ireland H91YR8E
, Galway
Originally Posted by Seanlb
Thanks so much for this Im living in Ireland and have been searching for a match for ages.
09-09-2021, 09:57 PM
2003 25' Safari
Las Vegas
, Nevada
Tried it numerous times over the years, and that included phone calls to the factory for the paint code. The spray can paint color does not match. It doesn't come close. Having the paint mixed, assuming you can obtain the code from the factory ( it won't be easy), will also not provide a satisfactory match. In addition, paint changes color over an extended period of time due to a variety of factors so touching up small areas won't work, and trying to match larger areas of your AS will not be successful. Simply change the shade of gray (assuming it is gray) and forget about trying to do the impossible, or change color altogether. You might try black if you're attempting to repaint the frame. The newer AS unit frames are black. Trying to match existing painted surfaces is an impossibility.
09-10-2021, 07:54 AM
1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
I agree with Hannibal01, paint and powder coats fade / change with age. I usually get a dark grey flat finish. Mask off A-Frame and banana wrap, clean and lightly sand then paint with Rust-Oleum or Krylon paint/primer combo rattle can. Everything matches that way.
Steve
09-10-2021, 09:30 AM
2016 27' International
Sherwood Park
, Alberta
Yes, this. The paint cans from AS do not match and are ridiculously expensive. I went from what I thought was going to be a 10 min touch-up to a 1/2 day job scuffing, taping off, and repainting the entire tongue. Looks great though.
If I were to do it again, I would use a good Rustoleum paint. Better paint and less than half the cost.
