He is correct it IS NOT plumb, it looks the same as ours did.
18yrs and they still can't get it straight.
There 'ya go put a better 'spacer' there...done & done.... maybe
Originally Posted by jmslade
Here you go.
Ok..it may be possible to space them out a bit. If they are attached like our manual ones are.
I had to space our lower mounts out and re-plumb them because the awning wasn't rolling up straight. I replaced the self tapping phillips head with stainless ST bolts.
It appears yours screw into a rib and may be attached the same way.
A 1/4" thick piece of composite under the mount plate should be enough.
The thinner the better.
