Old 05-17-2021, 07:05 AM   #1
2021 30RB Classic
NA , Maryland
Ceramic Coating
Hello,
We're still waiting for our AS Classic to be built, Covid delays...
I'm doing research while we're waiting and saw a thread on things people have done. Are there any thoughts or recommendations on using ceramic coatings on an AS? Is it superior to the Walbernize wax or do people combine them? It's an investment and I want to keep it in the best possible condition.
Thank you
jan55255 is offline   Reply With Quote
Old 05-17-2021, 07:39 AM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
If my AS was new, and I had the money, I would certainly consider doing a ceramic coating.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-17-2021, 08:01 AM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I will be having the ceramic process done to my Classic on the first of June. The research I've done (and this only applies to the process that Brian came up with at Vinnie's Airstream) has led me to want to have the process done to my trailer. This is not the same ceramic that is applied to cars. Brian thoroughly cleans and buffs the entire vehicle. Yes, I said buffs. He is able to remove any scratches that are not all the way through the plastic coat.
Brian has to clean the entire surfaces that will be coated as it will seal any dirt or grime under the ceramic coats. I say "coats" because he and his team spray 3 coats of ceramic on the trailer. The results are stunning!
You will not have to wax or Wabanize ever again. Water (and dirt) just rolls off the surface. The coating lasts as long as the trailer and in fact, will preserve the trailer. Filiform is an Airstream worst enemy. The ceramic coating will be absorbed by the rivet holes and the cut edges of the sheets of aluminum are also sealed.
This all sounds like the perfect coating, so what are the drawbacks? Well, the cost is somewhat expensive. My trailer (Classic 30) is going to run $3800. I probably would not do this if it were not for my visit to see my son and his family and the cost of campgrounds near him. $550/week is pretty steep until you get to leave your trailer at Brians for two weeks! That's like an $1100 savings that I can put toward the ceramic coating bring that cost to $2700. We have nowhere to park at my son's house so we rent a campground space. The storage options are available, but you park outside in a large lot with a spacing of one foot between vehicles. Lots are full of box trucks used every day by their owners and returned to the lot at night. Do you want to put your Airstream at risk?
The second problem I see is what if you get into an accident that requires the replacement of panels? Do you have to drive back to California to have the ceramic process done to the panels? Maybe you can use the auto ceramic in a pinch. I will find out from Brian.
I hope this helps you make that decision and I hope that Brian and Vinnie can distribute their process to others to perform this somewhat exclusive process.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 05-17-2021, 08:21 AM   #4
2021 30RB Classic
NA , Maryland
I'm interested in doing this, i just need to find a dealership in my area that does it that's affordable. Considering the cost of cleaning products and the time to clean it, it's an easy decision, understanding that it still needs washing. driving across several states to have this done isn't in the schedule.
Old 08-26-2021, 11:51 AM   #5
Originally Posted by jan55255 View Post
Hello,
Thank you
I used this for the first time this Season...works well and easy to apply.
It won't last as long as a professional Ceramic 9h will, but it's a LOT cheaper.
I did have both the Burb and DW's MB professionally done last year, could not be more pleased.
'06 Burb
I now question my ability to evaluate my inability to assess the observational state of my own percieved reality. 🤓
RLC
Old 08-27-2021, 08:02 AM   #6
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Vinnie is opening a Ceramics application shop in Florida this fall. Stay tuned!
SuperTrouper is offline   Reply With Quote
Old 08-27-2021, 08:18 AM   #7
Be advised that all the Pro applications I researched,(including ours), require, as part of the 5yr(Burb) and lifetime(MB) warrantee, a yearly $100 inspection & top coat.
I consider it worth it for our two vehicles, not so much for the AS.
Do the research.👍
RLC
Old 08-27-2021, 08:27 AM   #8
2019 25' Flying Cloud
Houston , Texas
I explored this, but while it's described as permanent, it seems it needs inspection / reapplication. Good stuff I'm sure, but not actually permanent.
DCPAS is online now   Reply With Quote
Old 08-27-2021, 08:40 AM   #9
GB
gblackburn's Avatar
2016 27' International
1997 34' Limited
Saint Cloud , Florida
Do you know where in Florida? I am in central FL but travel all over the state.
Gil
"Everyone buys on emotion and justifies with logic.
That is why I own an Airstream... I needed it."
gblackburn is offline   Reply With Quote
Old 08-27-2021, 08:47 AM   #10
Correct it is NOT permanent, same as the Alcoa clear coat.
It is a very thin nano coat, the surface it's coating must be very clean and blemish free for the best results.
Is your AS blemish free?
Our's was NOT described as permanent.
Again do the research, an honest disclosure is important.
POI...washing both vehicles is a breeze now, spray on wash foam microfiber softly and rinse, very little sticks to the surface and spray ceramic is great for the glass.
RLC
Old 08-27-2021, 01:23 PM   #11
Tallahassee: http://www.vinniesairstream.com/contact-1
LOLOHO video about same:
Old 08-27-2021, 07:06 PM   #12
2017 25' International
West Lake Hills , Texas
What does Vinnie do that magical? Im asking about the process.
Fungus is offline   Reply With Quote
Old 08-28-2021, 05:58 AM   #13
I guess he sprays it on...it works just as well with hand application but would take a lot longer with a larger unit.
This is how Titan Motorworks did our vehicles with Ceramic Pro 9h...It's also the way I wash, with a foam canon from Chemical Guys & Griot's Concentrate Car Wash.
RLC
Old 08-28-2021, 08:58 AM   #14
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Pro tip: When you spend $3800 for that sprayed-on (three coats of varying formulas!) ceramic coating on your Airstream, use the two bucket method to wash it. One bucket of soapy water and one bucket of clear cool water to rinse the dirt, oil, and what Bryan describes as "sand", off the brush you use.
It's amazing how much dirt comes off the brush that you would normally be putting back on the surface if you only use only one bucket.
Tools needed: https://www.amazon.com/anngrowy-Micr...xpY2s9dHJ1ZQ==
https://www.amazon.com/Chemical-Guys...xpY2s9dHJ1ZQ==
Buy two wooly mammoth towels! These towels are amazing!
Tom & Doty
Old 08-28-2021, 09:29 AM   #15
Mollysdad's Avatar
With my luck I'd pull out of Vinnie's shop into a baseball sized hail storm!
Old 08-28-2021, 09:30 AM   #16
Two buckets not needed with the foam cannon!!👍
A hose & water pressure will suffice.
RLC
Old 04-17-2022, 02:28 PM   #17
2022 28' Pottery Barn
\_(ツ)_/ , California
Any updates from anyone on recent applications, prices, effectiveness or longevity?
Thanks!
WellSaid11 is offline   Reply With Quote
Old 04-17-2022, 02:35 PM   #18
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I had it done several months ago in Tallahassee. So no report on longevity. But I can say the AS never looked better and it seems to stay cleaner longer (as in dirt doesn't stick to it).
Hans627 is online now   Reply With Quote
Old 04-17-2022, 02:40 PM   #19
TY Hans!
What size is your AS and do
you mind me asking how much it was total or by the foot, etc?
You can PM me if you want as well.
Old 04-17-2022, 02:50 PM   #20
2021 30' Globetrotter
Oviedo , Florida
Beautiful. Just spent 2 days washing and waxing mine. I generally wax it twice a year. Good way to find missing rivets
jondrew55 is online now   Reply With Quote
Ceramic Coating An Airstream? djarrett Cleaning, Stripping & Polishing 53 06-07-2022 08:30 AM
Ceramic coating Kaos1 Exterior Restoration Forum 10 01-29-2021 07:39 AM
Ceramic Pro Coating gzvette61 2016 - Current Flying Cloud 15 05-30-2020 11:47 AM
Ceramic coating (IE F-11) Maggsy Clearcoat, Exterior Paint & Trim 0 10-23-2019 04:34 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
