Old 06-19-2023, 08:23 PM   #1
Wiltstream's Avatar
2005 25' Classic
Lexington , Ohio
BRN Removal
We’ve removed our big red numbers but the “sticky” residue is there. Looking for safe option to remove it but not impact clear coat. Thanks!
Wiltstream is offline   Reply With Quote
Old 06-19-2023, 08:41 PM   #2
2007 22' International CCD
BRN Removal
Search for “Rapid Remover” online. Used by vinyl sign companies to take off old sticky vinyl film.
It’s usually available on Amazon or Walmart. Be cautious around glued on plastic Airstream logos because it also removes them efficiently. Takes BRNs off easily with the use of a few plastic razor blades and soft cloth without scratching the clear coat.
Old 06-19-2023, 10:02 PM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
BRN Removal
I wonder if heating the residue with a hair dryer would soften the glue to make it easier to remove? That method has worked for removing the BRNs without leaving residue.
4RXLA is offline   Reply With Quote
Old 06-19-2023, 10:19 PM   #4
2016 27' Flying Cloud
Little rock , Arkansas
This melts it like butter. A good NAPA should carry it:
3M Specialty Adhesive Remover, 38987, Solvent-Based, Removes Reactive Adhesives, 15 fl oz https://a.co/d/j7LExgq
Dtrentr is offline   Reply With Quote
Old 06-20-2023, 05:41 AM   #5
SlowPokePete's Avatar
2020 25' Globetrotter
Hillsdale , New York
You can also try WD-40.
SPP
SlowPokePete is online now   Reply With Quote
Old 06-21-2023, 05:33 AM   #6
Wiltstream's Avatar
2005 25' Classic
Lexington , Ohio
Thank you for the suggestions!
BRN on rear of trailer Bluetick On The Road... 12 07-12-2022 06:06 PM
Where to get BRN? Hans627 WBCCI Forum 9 04-08-2022 08:43 PM
Rivet Removal Tool OR Blind Rivet Removal T mkamanu General Interior Topics 3 10-12-2015 08:29 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 08:58 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 02:00 PM
