Old 04-07-2020, 12:53 PM   #1
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Window Guard fastener upgrade
Back in 2017, AirMiles posted a great idea for improving the window guard 1/4 turn fasteners with permanent stainless threaded bolts and nylon nuts.
Unfortunately I cannot get ahold of AirMiles to ask, what is the specific size of stainless bolt, washers and nuts that you used in the repair.
Has anyone repeated this project? What sizes did you use? Thanks.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 04-07-2020, 06:49 PM   #2
2016 30' Classic
Houston , Texas
I like the idea. Shouldn't be hard to determine the needed parts. Thanks for sharing.
dhroberts is offline   Reply With Quote
Old 04-07-2020, 10:32 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
That machine screw is a 10-24 based on the looks in the photo
Old 07-27-2020, 10:00 AM   #4
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Nice idea if there's a danger of the curved window rock guard covers unintentionally coming open somehow. While I can't really see the need to do all of this if your middle window covering is like mine, as it closes over the flanges of the curved window covers locking them down securely for travel. Thanks for posting this.
If one needed to do this it's fairly easy. The quarter turn fasteners are easy to remove (from experience). Just drill them out with a #30 bit. It will remove the original pop rivet without enlarging the hole. Then it will be easy to determine the size and length needed for the machine screws, the flat nuts and the nylock nuts. Then just use some Tremco TremPro 635 or Sikaflex 221 in the rivet holes, the backside of the fastener flanges and on the grip side of closed end, domed 1/8" x 1/4" rivets. After assembly simply wipe off any squeeze out (if necessary) with a plastic razor blade or putty knife followed by a squirt or two of mineral spirits on a shop towel.
Pretty easy and straightforward. As for the curved rock guards you would still need to remove the fastener screw (probably just cut it off) and enlarge the hole if necessary for the new machine screw shank to fit through.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Window Rock Guard Twist Fastener and Gromet Won't Hold BayouBiker General Repair Forum 7 03-10-2020 04:52 AM
curved wing window fastener jdix Rock Guards, Segment & Window Protectors 5 10-01-2016 03:10 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Where to buy black rubber window fastener/clasp Sobotik Windows & Screens 9 01-07-2013 11:57 AM
Window guard fastener pagoff Rock Guards, Segment & Window Protectors 8 04-22-2006 08:57 AM
