Old 05-29-2024, 05:50 PM   #1
MOS
2023 19' Caravel
Queensbury , New York
What to do with the front window solar guards ?
My front window solar guards are a mess . I have tried window scratch remover and cleaner . They still look bad in the sun .
So can they be repaired or replaced with different material ?
If so , who and where ?
Mike
MOS is offline   Reply With Quote
Old 05-29-2024, 07:54 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
How did they become damaged on a 1 year old trailer?
CRH is offline   Reply With Quote
Old 05-29-2024, 10:09 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
The acrylic can be replaced with new. Not aware of any glass panels that could be used, but I wouldn't want glass up there anyhow - too heavy, too prone to breakage from gravel and such, and it would be way too expensive.
Hard to understand how yours got beyond use in just one or two years. Mine are decades old and still doing their job.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 05-30-2024, 03:46 AM   #4
MOS
2023 19' Caravel
They are only bad when the sun hits them . I like my windows clean and clear .
Who or where came do the replacements
Old 05-30-2024, 04:45 AM   #5
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
Wether new or old try a product called Plexus on them. It will not only protect the plastic but help fill in the scratches. Made for aircraft windows.
Keys Dave is offline   Reply With Quote
Old 05-30-2024, 04:56 AM   #6
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
Ours are clean and in great shape after seven years. Barring damage from an impact, I don’t expect they will ever need replacement.
They are darkly tinted by design so will never be “clear.” But using scratch remover on them probably made them hazy.
2017 Bambi 19 Flying Cloud
BikeCamper is online now   Reply With Quote
Old 05-30-2024, 05:17 AM   #7
MOS
2023 19' Caravel
I have done this a few times ….
Once again where and who will replace the material without buying new ones ?
Old 05-30-2024, 06:02 AM   #8
dznf0g's Avatar
Oswego , Illinois
I replaced my own with polycarbonate rather than acrylic (plexiglass). Much more impervious to rock cracks, BUT they all scratch. It is the nature of the animal. Sorry, it's true. I know of no one who does the material replacement instead of the whole guard replacement. It's rather labor intensive and with labor rates what they are.........
-Rich-
Old 05-30-2024, 09:31 AM   #9
Glen Carter's Avatar
2018 19' Tommy Bahama
Downey , CA
My '18 Tommy Bahama had the graphics on the front, however the clear protective cover went bad. There was improvement as I was able to remove some of the clear layer, however I ultimately had to remove all of it.
Having graphics printed and applied is an option, however visibility from inside is reduced. Perforated graphics is about 50% Pictures were Jan 22.
ID:	443851   Click image for larger version
ID:	443853   Click image for larger version
Glen Carter is offline   Reply With Quote
Old 05-30-2024, 09:50 AM   #10
2019 25' Flying Cloud
Houston , Texas
You can see the process:
DCPAS is offline   Reply With Quote
Old 05-30-2024, 10:19 AM   #11
2020 30' Classic
2015 25' Flying Cloud
Blue Ridge , Georgia
window guards
I use Walbernize polish the same stuff on the trailer and it works fine to clean and polish my front window guards.
Gleverett is offline   Reply With Quote
Old 05-30-2024, 10:55 AM   #12
Boba911
Warwick , Rhode Island
I have the same Tommy Bahama model and would like to know if you had a signed shop redo the graphics and install them??
Boba911 is offline   Reply With Quote
Old 05-30-2024, 10:56 AM   #13
2015 16' Sport
2017 22' Sport
Coral Canyon, Washington City , Utah
Walbernize is GREAT
I concur 100% Apply in a shaded, no direct sun, area with cloth, polish with a variable speed polisher with soft pad. Work in small area at a time.
MrStreamer is offline   Reply With Quote
Old 05-30-2024, 11:10 AM   #14
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Originally Posted by DCPAS View Post
Thank you for sharing that video. Our 2005 rock guards do not have any holes in them, but they have several cracks that can be seen in certain light from the inside. Another project...
10Smiles is offline   Reply With Quote
Old 05-30-2024, 11:21 AM   #15
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
Care & Feeding of Rock Guards
Meguiars makes a line of cleaner and glazes for were developed for the military to use on aircraft cockpit windows. The motorcycle industry adopted the for their windshields. It works very well for rock guards.
It is a 2 step process. Starting with their #17 Plastic Cleaner followed by their #10 Plastic Polish.
cbburke is offline   Reply With Quote
Old 05-30-2024, 01:22 PM   #16
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
Plexus is impossible to find now if you know a connection please share I’m on my last can
Life is a Highway is offline   Reply With Quote
Old 05-30-2024, 01:36 PM   #17
2019 22' Sport
High River , Alberta
Consistent with some previous responses, a coat of wax can fill in fine scratches and make them look better. (Believe or not, you can do this with scratched eyeglasses, but the benefit is obviously short-lived.)
A synthetic product compatible with plastic is probably preferred.
AlbertF is offline   Reply With Quote
Old 05-30-2024, 05:55 PM   #18
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
Mos, if you cannot replace your plexiglass yourself, JC or a dealer can do it for you. I think each solar guard is around $500-600 each plus labor. Good luck and enjoy your trailer. Not sweating the small stuff may make your experience better. Things happen when you use them.
Dave & Carolyn
WBCCI #2584
davidrrand is offline   Reply With Quote
Old 05-31-2024, 06:49 AM   #19
2019 25' International
Washington , Washington, D.C.
One way to have 'clean and clear' windows is to simply remove the window guards and go without.
PatLee is offline   Reply With Quote
Old 05-31-2024, 08:33 AM   #20
BikeCamper's Avatar
This is yet another reason why I would like to see the layout of the 19 (and some others) flipped front-to-back. With the dinette and wrap-around windows at the rear, not only would the camp view be better when backed into a site, but you could also eliminate the plexi window shields/solar guards. Better and clearer view, less weight, less cost.
Replacing your plexi glass Rock Guards / Stone Guards PeterH-350LE Rock Guards, Segment & Window Protectors 70 07-05-2023 12:08 PM
92 Excella 29; front window rock guards Mossyrock Airstream Classifieds 0 08-05-2016 12:55 PM
Front Window Guards bebling All Argosy Trailers 7 03-04-2013 07:52 AM
Front window stone guards 2006 Classic 30' S/O kleimanr 2006 - 2010 Classic (all lengths) 7 07-25-2006 10:33 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
