Old 06-27-2018, 09:15 AM   #1
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
Segment Protector Hold-Back source?
My 2001 Bambi 19 has SS segment protectors. They attach via a hinge, a rubber isolator and a 5" hold-back bracket. The hold-back bracket is an aluminum extrusion 5" long with 6@ 1/8" rivet holes along the edge and a single 1/4" bolt in the center. I need to replace one of the hold-back brackets and the aftermarket part I ordered has 3/16" rivet holes in the wrong locations and a 5/16" hole for the 1/4" bolt. In other words, they sold me a blank that has been ruined by improper hole drilling. Where can I get an undrilled piece of the aluminum extrusion so that I can drill it to match the perfectly useable 1/8" holes already in my trailer?
Aironius is offline   Reply With Quote
Old 07-07-2022, 06:04 PM   #2
2015 25' International
Sandy , Utah
did you find a source for this? I need the same thing! My 2015 AS international has 2 3/4" long pieces and all they sell now is 2" I don't want to have to fill the holes from the old locations then use the new ones.
BoomS9665 is offline   Reply With Quote
Old 07-07-2022, 06:52 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
What's the dimensions, I could try to make one. I know I could bend up a repair channel that would fit into the back. Need dimensions in thousandths
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
Old 07-07-2022, 06:59 PM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Any of these work?
https://www.woodlandairstreamparts.c...ment+protector
Richard
11018
richard5933 is offline   Reply With Quote
Old 07-08-2022, 07:38 AM   #5
Aironius's Avatar
2001 19' Bambi
I see some replies and will address them all. I have fixed the old part. I found a piece of hard aluminum bar stock in my junk pile, filed it to exactly fill the radiused interior of the bracket, riveted it in place. I drilled and tapped a hole through the new metal and inserted a SS 1/4"NC bolt from the rear, then riveted the bracket back to the original holes. A SS washer and cap nut finished the job. No photos because I already reattached the segment protector. Also replaced the rubber retainer at the bottom and new rivets in all the hinges, etc. Better than new!
The replacement brackets shown in Richard5933's post look like what I had bought. The short ones are shorter than stock and the long one looks too long, so all would require new holes drilled in trailer.
Old 07-08-2022, 10:18 AM   #6
Aerowood's Avatar
Arvada , Colorado
Good job
Need a source for Segment Protector latch R&SZinser Rock Guards, Segment & Window Protectors 10 02-28-2019 12:57 PM
Segment Protector install equigley 1969 - 1973 Safari 3 02-07-2015 08:05 AM
Segment protector ticki2 Rock Guards, Segment & Window Protectors 4 10-21-2008 06:53 PM
Segment Protector Corrosion chaunceyboy Ribs, Skins & Rivets 27 06-14-2007 08:05 PM
?? Lower segment protector fit ?? driftwood Rock Guards, Segment & Window Protectors 1 03-07-2005 05:09 PM
