04-28-2020, 06:25 PM
2019 23' International
Portland
, Oregon
Rock guard rubbing
This is what I found when I took off the right hand rock guard. Sent a picture to the dealer and they said it looks like there is no contact other than the attachment points and I should clean it with barkeeper's friend. Does that make any sense ?
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
04-28-2020, 06:40 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
No dents or warpage?????
Cleaning may make it less noticeable but what keeps it from happening again?
It should not touch at all...
04-28-2020, 06:54 PM
Oswego
It appears to me that something dark and blackish got wedged in there sometimes and itched a worn spot. Then the filiform corrosion started.
-Rich-
04-28-2020, 07:41 PM
Portland
, Oregon
Nothing fell out. Guess I have to look in there with the borescope when it's shut.
04-28-2020, 08:00 PM
2018 25' International
Slidell
, Louisiana
The black is most likely oxidixed aluminum dust from the back of the rock shield mixed with road grime. Mine rubbed too. I polished out the damage with some polishing compound then gringot's Garage All In One Sealant and then used some 2 inch pvc pipe and some thin plywood on the trailer side set vertically the distance of the guard at the rub spot and partially closed it to reshape the guard so it won't rub any longer. I used a light looking up from the bottom to verify the reshaping worked. Saved a 120 mile round trip to the dealer.
04-28-2020, 08:09 PM
Oswego
Mine rubbed too. But it was due to a crease under the guard which caused a high spot. Either born that way or PO did something. Looked nothing like that.
-Rich-
04-29-2020, 10:38 AM
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
What does the inside of the rock guard look like?
edit: oops!  I see now that that is the second pic you posted.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
04-29-2020, 05:04 PM
Portland
, Oregon
So the dealer looked at the pics and said clearly something fell in there and they’d quote me a price to fix. But then I shot these with a fiber optic cam. We’ll see what they say.
04-30-2020, 08:36 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Well, you certainly have proof that they are wrong.🥴
If there is no indication of any impact, it's bent, most likely from an improper install. Clearance should have confirmed at hinge and retainer mounting.
04-30-2020, 11:21 PM
Portland
, Oregon
[emoji631]
Yeah they are gonna take their own pix next week and fight with airstream for me.
05-02-2020, 02:42 PM
2016 30' Classic
Houston
Don't hesitate to contact JC's Warranty Dept directly as I assume the dealer will start dancing with the hope you go away. I contacted JC directly several times on different topics - worked well.
05-02-2020, 04:26 PM
2013 30' Flying Cloud
Kingwood
When talking to Airstream you might refer to them as Segment Protectors rather than Rock Guards. The Rock Guards cover the glass areas and are sometimes called Sunglasses.
05-02-2020, 10:50 PM
Portland
, Oregon
Originally Posted by dhroberts
don't hesitate to contact jc's warranty dept directly as i assume the dealer will start dancing with the hope you go away. I contacted jc directly several times on different topics - worked well.
jc?
05-03-2020, 06:29 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
jc?
Jackson Center Ohio...The Factory.
If you get them involved you stand a better chance of a satisfactory result.👍 Direct phone calls & email...do NOT depend on the dealer to do all the leg work.🥴
05-03-2020, 06:46 AM
2018 27' Globetrotter
Mooresville
, North Carolina
I’m not saying this is your situation but I know a guy that had this issue and the root cause was a frame separation issue on his front end of the RV. As others have stated I think Jackson Center would be the best to diagnose the cause.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
05-10-2020, 03:34 PM
2019 27' Globetrotter
Olympia
Missed if this is a fairly new trailer but took my 2019 27’ GT in for some warranty work and the dealer actually discovered the segment protector was rubbing. They said they’ve seen this several times before and an incorrect install. Dealer filed the claim with JC and no issue to send a new guard. Seems like a known issue at JC so hopefully, you will get a quick resolution.
05-10-2020, 10:29 PM
Portland
, Oregon
Went to the dealer and they will get authorization to replace the guard and the quarter panel.
