Old 08-02-2017, 10:32 AM   #1
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
Replacement Window Rock Guard
Lots of threads on this, but cut to the chance. To replace the smoked rock guard, are there any other options other than buying the entire unit at about $1,500.00.
I just need the plastic smoke glass replaced, not the frame work.
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
philipsinewe is offline   Reply With Quote
Old 08-02-2017, 11:00 AM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Yes, you can replace just the plexiglass if you are willing to disassemble the frame.
Remove from the trailer, remove weatherstrip, drill out rivets on closure part of frame, frame has 90 degree angle in the corners that you slide out of alum frame, remove old plexi and rubber cord, use old plexi for pattern and cut out new, reverse process.
I replaced mine with Lexan but now not sure if that was the best way to go, costs more and more impact resistant than plexi but not sure if it's as scratch resistant. I cut the Lexan with a jig saw and a fine blade.
Cost me $270 mainly because I had to ship full sheet, others have own ideas on this.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 06-29-2018, 09:23 AM   #3
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
replacing rockguard plastic
My '01 Bambi has a single front window with smoked plastic rock guard, hole and cracks in lower RS corner. I removed the frame and drilled out the rivets as outlined above, and removed the old 1/8" plastic and rubber seal strip. The shape of mine is a simple rectangle with 4" radius corners, so I made a shop drawing and had a shop in a nearby city cut me some 1/4" smoked polycarbonate. I don't recall the mfg. or grade, but it was one step below the bullet-proof stuff they use on trains and buses. Put it into the clean channel with a little clear silicone adhesive (no rubber gasket with thicker material) and riveted the frame back together. Better than new!
Aironius is offline   Reply With Quote
Old 08-20-2020, 03:33 PM   #4
1978 31' Excella 500
SOUTH ANHERST , Ohio
I have a front window window rock guard , now here is my issue I was stripping my clear coat and had the window rock guard coveted but some how got a 2" section a bit of stripper on the guard and did not see it because all was covered so now is the guard toast or is there any way to fix the mark with out replacing the whole plex glass.
Need you help out there will be waiting.
Thanks All
Gosman is offline   Reply With Quote
Cheap Front Window Rock Guard Hotlead Windows & Screens 5 08-14-2019 09:45 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Window Rock Guard balrgn Rock Guards, Segment & Window Protectors 6 10-30-2004 04:00 AM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
