Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 07-09-2017, 05:48 AM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Plexi front window Stone Guard
Mu subject stone guard is scratched and shows a PO club number into the plexi. I do not like the idea of spending many hundreds to buy a new assembly.
Could this be painted or somehow tinted (perhaps both sides) so as to not see this? I do not care if I can see through it as it will always be opened when parked.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 07-09-2017, 06:03 AM   #2
Retired.
. , At Large
If you're mechanically inclined, you can simply buy a piece of smoke color plexiglass, open the rock guard (off the trailer), and replace it. It should cost much less than a new center rock guard.
Old 07-09-2017, 06:58 AM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Check classifieds
Here is a set posted this morning
Maybe you can work something out with this guy.
http://www.airstreamclassifieds.com/...ma-rock-guard/
Old 07-09-2017, 07:09 AM   #4
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
I have a 1989 AS Excella 29. If yours would fit my unit, I would be pretty interested. Perhaps we could compare dimensions?
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 07:13 AM   #5
Retired.
. , At Large
The ad is for a "ISO" rock guard. He doesn't have one, and is looking for one.
Old 07-09-2017, 03:02 PM   #6
2016 30' Classic
Glenwood Springs , Colorado
Try Plexus
If you go to a motorcycle shop and buy some Plexus. It's used to clean and polish helmet wind screens. It might work. I've had great luck with it. I just cleaned my stone guards with it. Good luck
rstull12 is offline   Reply With Quote
Old 07-09-2017, 03:05 PM   #7
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
I have tried Novus (all three strength levels) and it cleans and polishes fine. But, it does not remove the scratches nor the white appearance in the plexi.
I have used both Plexus and Novus on my cycle windscreens and they worked quite the same.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 03:38 PM   #8
brokeboater's Avatar
2013 25' Flying Cloud
Crystal River , Florida
I was wondering how you were doing with your 29. I'm still searching but my white box will do until the right rig pops up.
I replaced the plexi in my first Airstream. A few pop rivets and screws, a little caulk, some sailor talk (well, maybe not you), and you're good to go. Mine was about 1/2" over half a full sheet. I went to a glass supply place and they cut it for me, not the rounded corners. I did the corner cuts at home with a jig saw. I was able to sell both drops on Craigslist so my cost wasn't that bad. It came out just fine.
ID:	289071   Click image for larger version
brokeboater is offline   Reply With Quote
Old 07-09-2017, 05:01 PM   #9
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Still toying with all the suggestions and ideas. My local (tiny town) auto glass shop will only sell me a whole sheet. That puts it up near the cost of a new one from AS.
So, looking at painting with Krylon's Fusion spray paint. Not sure it would match, but it would look better than currently.
Good luck in your AS quest!
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 05:14 PM   #10
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
To add further confusion:
If you have any choice at all, you don't really want Plexiglass. You want Lexan. The difference in strength is significant. I have no idea which one JC supplies on a replacement order.
Old 07-09-2017, 05:16 PM   #11
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Hi
Yes, I'm sorry. I meant Lexan in my questions.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 05:33 PM   #12
Yes, mine was Lexan also. I live in a small town also. Even the bigger town I'm close to didn't have anything. I ended up buying mine 200 miles from home when I was there on other business. I had to buy a full sheet also and the place cut it to order. Apparently Lexan is hard to come by in small towns because, like I said, I sold my cut off drops proportionally cost wise to the whole sheet and the folks were very glad to get them. By picking it up when I was in town on other business and selling the drops it kept my cost reasonable.
Old 07-09-2017, 06:19 PM   #13
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
On EBay you can get partial sheet sizes of dark lexan 1/8" or whatever your after shipped to your door
AlinCal is offline   Reply With Quote
Old 07-09-2017, 06:20 PM   #14
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Thanks.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-09-2017, 06:28 PM   #15
AlinCal's Avatar
1991 25' Excella
That's the most economical source I've found and I'll be getting a full sheet to do all three. I was surprised to find only 1/8" in mine after disassembly but it answers the problem of forming the side units. They roll it to ship larger peices so it is flexible.
Old 07-09-2017, 06:29 PM   #16
Retired.
. , At Large
Hi
OEM material is plexiglass.
Old 07-09-2017, 06:31 PM   #17
AlinCal's Avatar
1991 25' Excella
Lexan is what I've been looking at too.
Old 07-09-2017, 06:33 PM   #18
Retired.
. , At Large
Lexan is much better, though more expensive.
Old 07-09-2017, 06:48 PM   #19
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Lexan
Lexan is the BEST for your project! Be sure to order the scratch resistant product. Lexan is up to 5 times as strong as plain Plexi. After all you want what protects your glass the best! Great thing it is the center panel that needs replacing as it is difficult to bend for side curved windows, but can be done. Good luck! Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-09-2017, 06:50 PM   #20
I couldn't find anyone on ebay to quote a sheet over 48". Mine was like 48 1/2". If it's under 48 X 48 then ebay is a viable source.
Cracked Plexi Rock Guard Roadtech Rock Guards, Segment & Window Protectors 40 08-28-2016 08:23 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Stone Guard Window Gaskets SteveSueMac Windows & Screens 4 08-27-2014 07:10 AM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Window Stone Guard What to do? 05ModPod Rock Guards, Segment & Window Protectors 30 08-31-2006 09:49 PM
