Old 07-09-2017, 09:00 PM   #21
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Originally Posted by brokeboater View Post
I couldn't find anyone on ebay to quote a sheet over 48". Mine was like 48 1/2". If it's under 48 X 48 then ebay is a viable source.
http://www.ebay.com/itm/like/361831120352?ul_noapp=true
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-10-2017, 05:13 AM   #22
brokeboater's Avatar
2003 25' Safari
High Springs , Florida
Originally Posted by AlinCal View Post
I'm pretty sure the intent was to not buy a full sheet. At a price you can get anything. I asked a couple of sellers on ebay to quote me a partial sheet the size I needed and they declined. That's $250 for a full sheet. I paid $101 for a full sheet cut to my specs. I sold the drops for $48 so my cost was $53.
brokeboater is offline   Reply With Quote
Old 07-10-2017, 05:35 AM   #23
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
Originally Posted by overlander63 View Post
The ad is for a "ISO" rock guard. He doesn't have one, and is looking for one.
He DOES have one it is just the wrong one for his trailer. READ! Want to trade or buy.
If he want to trade he has got to have somthing
Old 07-10-2017, 05:38 AM   #24
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Okay, trying again:
He does NOT have the part that the OP on this thread is looking for. He is looking for the same part. READ!
Old 07-10-2017, 06:03 AM   #25
PianoTech
tjplus's Avatar
2017 27' Flying Cloud
Lansdale , Pennsylvania
I'd use a dark magic marker and call it done.
tjplus is offline   Reply With Quote
Old 07-10-2017, 08:54 AM   #26
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Use Mothers headlight restore kit and buffer with a foam pad set at 1100 rpm
Old 07-10-2017, 12:16 PM   #27
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There are a bunch of places out there that will custom cut Lexan sheets to your spec. You need a drawing, but that's about it. I do mine up in CAD, so I'm sure it's dead on. I have used several different outfits over the years. Each one more or less randomly selected by Mr. Google. It's very much a no muss / no fuss kind of thing. In comes the piece and it drops right in. The same thing applies to stainless steel sheet and aluminum sheet for other projects.
Old 07-11-2017, 04:34 PM   #28
Frederica , Delaware
X2 Kits come with sandpaper to remove your scratches and marks. Although a trip to an auto supply house you can buy full sheets of sandpaper which you might need. Lots of elbow grease will be required. Auto body repair shop may be willing to do the work as well (they have power tools to make job go faster and easier).
Overloaded is offline   Reply With Quote
Old 07-11-2017, 04:55 PM   #29
Moflash's Avatar
If its bad enough that it needs sanded use 1000 grit to start (on the bad area only)then 1500 and finish with 2000.Also dip the sand paper in water from time to time while sanding.Then use headlight restore kit.Total cost approx $40.
Old 07-13-2017, 10:45 AM   #30
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Tried the sanding. I did remove the scratches on the exterior quite well.
However, if you can see in the original picture (my first post), it appears that a PO placed their numbers on another piece of vinyl, and stuck that's on the plexi. The numbers area remains black. The white area is the area of the number area vinyl.
It appears to have literally "bleached" the tint from the plexiglass. No clue now.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 09-09-2018, 05:42 PM   #31
Loretto , Tennessee
Side Panel Needs to be Replaced
Hi,
I've researched this topic but can't find good instructions on how to shape either plexi or lexan for the side panels. Do you have any suggestions on how to do this or should I go ahead and purchase a new panel...$$$...yikes!
1989 Excella 25'
TNExcella is offline   Reply With Quote
Old 09-09-2018, 06:22 PM   #32
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by TNExcella View Post
Hi,
1/16" Lexan bends pretty easy. Cut a tagboard template to get the size and shape right first then use as pattern for the Lexan. Get UV resistant Lexan.
Old 09-10-2018, 04:02 PM   #33
Half a Rivet Short
Hi
Shaping plastic sheets is a function of heating them up and building a form to bend them over. Neither process needs to be very exotic.
Old 09-10-2018, 09:19 PM   #34
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Fr. J... howdy again! I would ask my flock... if any are traveling to a town, let you know and could pick up the Lexan... It may sound like a strange request from the pastor.. but, frame it around .. "I see the light.. but now I need shades"...
Peace...!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-11-2018, 06:59 AM   #35
AlinCal's Avatar
1991 25' Excella
Couple things I learned from actually rebuilding my 3 piece rock guards.
First is they are not formed to the shape but mearly held in the curved shape by the frame, being 1/8" thick it is fairly flexible and falls within the allowed bending radius the frame provides.
And second is Lexan may not be the best choice. It is superior in crack resistance but not in scratch resistance and now that our 2011 19fc needs one corner replaced I will be using plexiglass as original.
Will Rogers
Alan
Old 04-15-2019, 02:56 PM   #36
1977 31' Sovereign
Conifer , Colorado
Where can I buy the complete front rockguard with frame?
I need a front rockguard for my '77 Sovereign 31'. Inland RV lists one on their website (backordered status) but is there another source? I am awaiting a call-back from them and from my local Airstream dealer but any input on additional sources would be appreciated.
Thanks!
TUselton is offline   Reply With Quote
Old 04-19-2019, 10:48 PM   #37
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Front rock guard
Thanks!
TUselton, You might try Out of Doors Mart.com. They are a long time Airstream dealer and may have an NOS original part for your trailer. They are very knowledgeable and can most likely help. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 04-19-2019, 11:17 PM   #38
Jim J
Jim J's Avatar
2014 30' Flying Cloud
Maybe you could make or find a panoramic picture that you like. Have it printed on Vinyl wrapping material, Wrap it over your existing window. Someone else on the forum did this and it looks really cool. Another option is to overcoat the existing window with dark window tint material.
Jim J is offline   Reply With Quote
Old 02-18-2020, 03:51 AM   #39
2018 30' Classic
Lake Charles , SW Louisiana
Newbie Question on same/similar topic. I am planning to replace the entire center solar guard on a pre-owned 2018 Classic I recently purchased. I have purchased a new solar guard (complete with both plexiglass, aluminum frame and piano hinge).
To remove and install the center window solar guard, will I need to drill out and replace any rivets or is it (solar guard frame) attached to the front/top of the Airstream using only sheet metal screws? Also, I assume there is sealant used as well between the hinge plate and the surface of the Airstream body but being a "newbie" I don't know what type is used.
Will appreciate any comments, advice, recommendations.
rewillia is offline   Reply With Quote
Cracked Plexi Rock Guard Roadtech Rock Guards, Segment & Window Protectors 40 08-28-2016 08:23 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Stone Guard Window Gaskets SteveSueMac Windows & Screens 4 08-27-2014 07:10 AM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Window Stone Guard What to do? 05ModPod Rock Guards, Segment & Window Protectors 30 08-31-2006 09:49 PM
