Old 10-08-2017, 10:48 AM   #1
chrisetmike's Avatar
1967 26' Overlander
Haute-Aboujagane , New Brunswick
Help with stripping window "drip caps"
Hi
We are in the process of restoring/renovating a 1967 Overlander international. We have run into our first problem. We orderded painted alluminun drip caps( yes we do know that they weren't originally on this model and year. ) Our stumbling block has been stripping the paint off. The product we have been using for all our stripping so far is not working.
We can't be the only ones who had to strip the paint off these things! What did you use?
I have included photos of the type of stripper and the drip caps.
A huge THANK YOU for any and all help!
Chris
ID:	296504   Click image for larger version
chrisetmike is offline   Reply With Quote
Old 10-08-2017, 11:48 AM   #2
1979 23' Safari
Wayland , New York
Try some aircraft stripper. Usually available at big auto parts stores. It's nasty so use with care.
Old 10-08-2017, 11:55 AM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Could be powder coated?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 10-08-2017, 12:25 PM   #4
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I have just stripped the entirety of our Argosy, had 4 layers of paint, with Jasco stripper available at lowes. If you use this product make sure to wear nitrile gloves and be extremely careful not to get the product on yourself or anything that you don't want stripped. If the rain gutters have been powder coated sanding or media blasting is the only way I know to remove the finish.
ID:	296509   Click image for larger version
1973Argosy is offline   Reply With Quote
Old 10-09-2017, 06:54 AM   #5
1967 26' Overlander
Thanks for the reply, we don't have any Lowes store in this part of Canada but Jasco striper is available for purchase at Amazon.
I will be very careful with the striper, I don't think anyone wants me striped
Old 10-09-2017, 08:59 AM   #6
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Window Caps
This is probably too late to be of use but Airstream Supply sells them unpainted.
http://airstreamsupply.com/aluminum-drip-cap-1-3
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Drip, drip, drip. Or not to drip? Vitaver Plumbing - Systems & Fixtures 9 12-19-2016 07:25 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
