Old 07-11-2017, 11:28 AM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Front Window Guard Removal
To remove my subject Plexi rock guard, do I need to drill out the rivets and remove the whole frame, hinge unit, etc. from the body?
It almost looks as though the frame may slide into and out of the hinge track. The side window wings would have to be open, but it sure would be less hassle than the rivet job.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 07-14-2017, 12:23 PM   #2
Elk Rapids , Michigan
Hi,
Without looking at how it was installed I'm just guessing but the hinge may come apart. If not and it's riveted you will need to drill the old ones out.
If you are replacing it with a new one do you have plans for the one you're removing? I'm looking for a 3 piece panorama unit for my Argosy and would be happy to help with removing the old one if it's available.
John in Elk Rapids, MI
matthewsx is offline   Reply With Quote
Old 07-14-2017, 12:39 PM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
The upper hinge is 2 part, one is screwed to the shell the other is part of the frame,. You can either unscrew the whole unit or you can drill out the end rivet that keeps the hinge from sliding left or or right.
If the caulking looks poor I would say unscrew the unit so you can reseal it.
Once off, the frame can then be taken apart on one side to free up the plexi.
be carefull drilling out the rivets so you don't drill thru the entire frame.
Edit: mine is screwed to shell yours may be riveted?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-14-2017, 03:04 PM   #4
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Question Answer
Originally Posted by matthewsx View Post
Hi,
John,
I may replace it, but first I am going to try spray painting the plexi with Krylon Fusion paint. If I am not happy with my result, I will replace.
I will keep you posted after my painting attempt. It may be awhile as I am up to my eyebrows with the bride's "more important" honey do list.
Feel free to check back as I may forget.
Jeff
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Cheap Front Window Rock Guard Hotlead Windows & Screens 5 08-14-2019 09:45 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Front window obstructed by window guard....HELP! vincaroo Windows & Screens 9 06-16-2014 08:20 PM
Front Window Plexiglas Guard Replacement boltos Rock Guards, Segment & Window Protectors 29 08-25-2009 06:00 PM
