Old 04-18-2021, 08:10 PM   #1
2020 27' Flying Cloud
Decatur , Michigan
Front protection windows fitment
We have a 2020 27FB flying cloud and recently returned from a camping trip from Florida. The campground trees dropped lots of leaves and debris during our week stay. When we returned home I noted many leaves and debris between the front windows and their projectors. When taking a closer look I noticed the covers (rubber seals) on the bottom of protectors fit tight. The tops however have a 3/4 inch gap between gasket and body. This is allowing debris to slide down the body right between the windows. Can these be adjusted? I believe poor fitment from factory. Thanks
Bob May is offline   Reply With Quote
Old 04-18-2021, 08:51 PM   #2
St. Marys , Georgia
You have discovered the famous Airstream debris trap! All AS are designed so. A JC tech once informed that the purpose of the rubber strips is only to prevent slamming. This gap must be cleared or you may find rainwater buildup and eventual interior leakage.
peggy2ten is offline   Reply With Quote
Old 04-18-2021, 11:24 PM   #3
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Or, add a bit of rubber weatherstripping to make up the difference ... works for us.
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 04-20-2021, 11:27 AM   #4
Decatur , Michigan
Bend?
Anyone try to bend these to fit better? Window is plastic and frame is aluminum. Seems like a little better fit would be possible.
Old 04-20-2021, 11:31 AM   #5
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Not without relocating the hinge and front attachment points.
gandttimes is offline   Reply With Quote
Wheel fitment question - 1975 25' Tradewind RFP Wheels, Hubs & Bearings 0 09-12-2016 06:55 PM
fantastic vent fitment Dixie722 Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-31-2015 04:42 PM
Fitment/alignment/security of small curved compartment doors Gator113 Exterior Storage Compartments & Access Doors 11 08-03-2010 01:07 PM
Windows and front body protection Argy 78 Rock Guards, Segment & Window Protectors 6 02-06-2008 01:34 PM
77 Wheel Fitment Disk to Drum JimGolden Brakes & Brake Controllers 2 10-28-2005 04:35 PM
