Old 03-07-2018, 04:13 PM   #21
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
We drove to Alaska and back with WeatherTech "mud flaps" and Rock Tamers and returned with a couple of significant dings at the bottom of the left side rock guard. The sides of the trailer are pristine so I'm pretty sure the offending rocks came from my truck.
I generally agree with the "the dings prove your using it" point-of-view but I also installed a bugscreenwarehouse.com "bug screen" that is tough enough to stop rocks to the radiator and oil cooler (a perfect fit on my 2016 GMC), Scotchgard Paint Protection Film on the lights and leading surfaces, and a hood bug deflector. Except for a rock that badly ripped the Scotchgard on the right side mirror the truck came home completely unscathed. The mirror was undamaged and the film was replaced under warranty.
I'm going to replace the WeatherTech mud flaps with the GMC version because I was always carrying a load of sand and mud on the tubular running boards. I think the GM version will give better protection.
BillfromWI is offline   Reply With Quote
Old 03-07-2018, 05:02 PM   #22
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The segment protector is designed to be dented, and in doing so, prevent the segment behind it from being damaged. A $600 segment protector is cheaper and easier to replace when it becomes trashed than a $1200 segment.
Old 03-07-2018, 06:12 PM   #23
1999 30' Excella 1000
small town , Maryland
A little hammer on the back side, with a block of wood on the front...almost new again.
streaminwild is offline   Reply With Quote
Old 03-07-2018, 06:24 PM   #24
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Lafayette , Louisiana
More dings you have on the rock guards represents the more adventures you experienced, with your beautiful Airstream. You did not buy it to sit in the garage. Explorer, enjoy and let the little things pass you by. At 60 y/o I have a few dent's and dings, but still going strong!
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
Old 03-07-2018, 06:24 PM   #25
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I’m going to install protectors for the protectors that protect my rock guard protectors.
2019 Ford Expedition Platinum
Old 03-07-2018, 06:26 PM   #26
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Wayne&Sam View Post
Iím going to install protectors for the protectors that protect my rock guard protectors.
Nah, the protectors for the protectors are rubber. They're fine.
-Rich-
Old 03-07-2018, 06:27 PM   #27
dznf0g's Avatar
Oswego , Illinois
However, if you have a diesel, they need protection from the dpf regeneration.
-Rich-
Old 03-07-2018, 11:20 PM   #28
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
Our rock guards look like the surface of the moon. 50k miles will do the job. There will be impact wounds in your solar guards as well and this is just the way things happen. We lost our front solar guard (window) to a bird impact recently, AAA insurance helped here....
Knuff is offline   Reply With Quote
Old 03-08-2018, 06:18 AM   #29
2018 30' International
cary , North Carolina
Love it
gbradleync is offline   Reply With Quote
Old 03-08-2018, 08:09 AM   #30
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Rock guards are the plexiglas things that shield the front windows. Segment protectors are the metal guards at the bottom of the trailer. My trailer does not have the segment protectors. There is a deep dent or hole that is filled with bondo. I wish the PO had put the protectors on. I just bought a used set of rock guards for our second trailer. But so far have no way to mount them. We took a hit on the rock guard that would have wiped out the drivers side panorama window. Glad it was there. I might use the new ones as a replacement for the badly cracked one when we get back from Alaska this year.
Dents in the segment protectors? Would not be a problem to me.
Old 03-10-2018, 06:44 AM   #31
Johnnyooo's Avatar
2016 16' Sport
Colrain , Massachusetts
The rock guards are to protect the aluminum which is very easily damaged... The guards are doing what their supposed to do...Mud flaps can help some, but they will not stop rocks from hitting them...In life we are bound to get some lumps, bumps, and dings...Rock On...
Johnnyooo is offline   Reply With Quote
Old 03-11-2018, 08:13 PM   #32
Knuff's Avatar
Thought that the plexiglass things are called solar guards. But we are all on the same page, I think.
Old 03-15-2018, 03:21 PM   #33
2017 19' International
Rosemere , Quebec
I agree with the thoughts that rock guards are meant to be dinged. Even on of the plexi pano window guards took a hit on one of our first trips with our 25í. It left a crack, psp I just drillstopped it and acetone welded it.
What's an acetone weld ?
Projet2907 is offline   Reply With Quote
Old 03-15-2018, 05:40 PM   #34
2007 22' International CCD
Acetone weld is using a small amount of acetone to dissolve the plexiglass and seal up a crack. Usually done from the backside with the item laid flat. Use a tiny artists brush and do not drip anywhere you donít want to mess up.
rmkrum is online now   Reply With Quote
Front Curbside stone guard -Front Sun guard Projet2907 Windows, Doors, Locks & Vents 0 02-06-2018 07:26 AM
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 03:00 PM
Roof dents and front endcap dents martymcclain Roof 3 09-16-2017 12:54 AM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
