Old 09-06-2022, 03:12 PM   #1
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Check Segment Protectors
How often if ever to check between segment protectors and body of trailer?
Silvr_Bullet is offline   Reply With Quote
Old 09-06-2022, 05:52 PM   #2
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I would periodically hose out the space with water. Other than that, there doesn't seem to be anything else to do, unless you flush out some debris. In that case remove the nuts securing the panel, carefully opening the panel to clean and or wash the trailer.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-06-2022, 06:02 PM   #3
2017 19' International
2018 25' Flying Cloud
Monrovia , California
I've opened them up once in 4 years to clean and polish the body of the trailer. You do need to do this periodically to inspect the sealant on the lower rub rail. Leaks here can rot out your floor. They are tricky to bolt back in place. I striped one of the bolts and had to drill the rivets to remove and reseal the bracket to replace the bolt.
Kay0 is offline   Reply With Quote
Old 09-06-2022, 06:04 PM   #4
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I would check them initially to make sure they arenít touching the trailer skin. There are some where the protector was not arched properly causing it to touch the trailer skin and leave some nasty marks. If they are touching, I would attempt to re-arch them to avoid the contact.
Once that is confirmed I would think that seasonal opening and cleaning should be enough. I will do mine next year when I do the front window protectors.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Pound out dents in segment protectors? altamont Rock Guards, Segment & Window Protectors 9 02-07-2008 02:42 PM
Lower Rock Guards - Segment protectors Ed Emerick Rock Guards, Segment & Window Protectors 4 11-21-2007 07:55 PM
Owner's Poll: Rock Guards and Segment Protectors SmokelessJoe Rock Guards, Segment & Window Protectors 3 11-21-2007 08:32 AM
rock guards segment protectors joecj76 Rock Guards, Segment & Window Protectors 21 07-02-2003 11:54 AM
