Old 06-21-2024, 05:03 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
broken front plexiglass in the front, how to remove the bottom frame section
hello
recently going through road construction, a stone broke our front plexiglass window protector
AS wants more than $1000 to replace the whole unit
they wont sell just the plexiglass
i found a local shop that cut a piece that exactly fits the alum frame
i tried to remove the bottom of the frame, i removed all the rivets
the centre of the frame is loose, but i cant get the two corners removed
this is the flat piece covering the front window.
has anyone successfully replaced just the plexiglass?
how can i remove just the bottom section of the frame?
cheers
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 06-21-2024, 06:17 PM   #2
2016 22' Sport
WALNUT CREEK , California
I recently replaced my plexiglass for the same reason, and also had a devil of a time getting the frame apart, in fact, I could never get one joint apart and ended up just finagling the plex into place apart with three joints apart.
The problem is that the the 90 degree internal corner piece that slides into each side is a relatively tight fit, and when the frame is drilled and riveted from the outside, the internal corner piece can be deformed so that even if you drill the rivet out, the internal angle piece gets wedged in place and won't come out. I tried clamping the frame in a vise and using a hammer and wood block to try to drive the corner apart. That worked on one, but actually broke the corner piece on another corner. I had to get some aluminum bar stock and make a new corner piece to get things back together.
What i would recommend is:
1. Make sure that you have fully drilled out the rivet, all the way through
2. Try the vise/wood block/hammer approach to see if the joint comes apart
3. If it is not coming apart with reasonable force, see if you can get by with only 2 or 3 corners dismantled and still get the new plex in place.
4. If that doesn't work, not sure what else to do.
Good luck!
jmickow is offline   Reply With Quote
Old 06-21-2024, 06:21 PM   #3
2016 22' Sport
This thread may be helpful as well, be sure to read to the end.
https://www.airforums.com/forums/f46...-196079-4.html
Old 06-21-2024, 08:26 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I replaced mine. I just drilled out the rivets holding the corner keys and took one section of frame out.
CRH is offline   Reply With Quote
Old 06-21-2024, 08:37 PM   #5
waninae39's Avatar
NCR , Ontario
tnx for the link
i followed the steps and the new plexiglass is installed
tnx forum!!!
WBCCI# 21212
Old 06-23-2024, 08:50 AM   #6
2015 30' International
Escondido , CA
following
dsatwork is offline   Reply With Quote
Broken Window AND Broken Plexiglass Rockguard pianolaw Windows & Screens 0 02-16-2020 01:40 PM
70s Rock guard frame,w/o plexiglass.complete minus plastic dje650 Airstream Classifieds 1 06-28-2019 02:37 PM
how to remove inner plexiglass pane of double paned oval window? ray henton Windows & Screens 1 04-15-2012 04:04 PM
Question on Front Window and Plexiglass Kathie Neir Windows, Doors, Locks & Vents 3 11-05-2011 04:35 PM
Looking for front window plexiglass covers tslanier Windows & Screens 5 07-30-2006 05:02 PM
