Old 10-07-2023, 09:45 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have black painted Centramatics on my trailer, so no metal to metal contact corrosion.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 10-07-2023, 09:52 PM   #22
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by PC Conner View Post
Sometimes, I prefer ignorance.
Were steel wheels so bad that we replaced them with the slicker looking aluminum wheels (used to call them mags). I would go back to steel wheels if I could. No complications and virtually indestructible.
It's all about looks!!!
"Mag wheels" or just mag was short for Magnesium. Magnesium wheels were manufactured from an alloy that was mostly magnesium. Could be cast or forged. First used in racing because they were very light and strong at the same time. Desired properties in wheels or other un-sprung suspension parts. The down side is corrosion.
Aluminum is use for wheels and it is an alloy as well.
A better term for those wheels that looks so better would be alloys.
As to steel wheels, why not go back to those. On a trailer, there is not much reason for light weight. Steel is far more stable. It is all about looks.
Action*
Old 10-07-2023, 11:57 PM   #23
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
It seems that each wheel is to remain on the same hub and marked so it can be replaced on the hub at the same position (such as 12:00 o'clock).
Then the suggestion is to wire brush the surfaces.
This seems to make it extremely difficult to have the tires replaced at a tire shop. ....
All depends on the shop doing the work. When I had my vintage coach I took it to a heavy diesel shop which worked on fleet buses. They had a tech (Jack) who was fastidious and did amazing work. If he pulled a wheel for any reason, it was not put back on until he thoroughly wire-wheeled all the studs to make sure that the lug nuts went on smoothly and torqued properly. He also clean all mating surfaces each time. Watching him work was amazing.
But, I paid dearly for Jack's services. It takes time to be so particular about the work being done, and shops that charge a flat fee aren't going to allow their techs to spend this kind of time on things. I agreed to pay an actual hourly rate on repairs so that I could get the level of service I wanted.
And then, there is the whole concept of just learning to do things myself. When the work was things that I can do, like removing wheels on my Airstream, I do them myself. This allows me to spend all the time necessary to get it done correctly.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 10-08-2023, 04:41 AM   #24
2014 27' Flying Cloud
Wenatchee , Washington
Originally Posted by richard5933 View Post
All depends on the shop doing the work. When I had my vintage coach I took it to a heavy diesel shop which worked on fleet buses. They had a tech (Jack) who was fastidious and did amazing work. If he pulled a wheel for any reason, it was not put back on until he thoroughly wire-wheeled all the studs to make sure that the lug nuts went on smoothly and torqued properly. He also clean all mating surfaces each time. Watching him work was amazing...
People like “Jack” are cheap at half the price (and I would gladly pay it). Sadly, “Jack” is extinct.
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 10-08-2023, 05:12 AM   #25
2017 19' International
Tallahassee , Florida
Originally Posted by Life is a Highway View Post
Huge controversy , on techs know the right answer
So ... what's the big secret?
WhereStream is offline   Reply With Quote
Old 10-08-2023, 05:57 AM   #26
1994 25' Excella
Hard to find, but not extinct. This shop has a full cadre of apprentices learning the ins and outs, all competent in their own way. I try and seek out similar shops when I need work done on my trailer or vehicles.
Richard
11018
Old 10-08-2023, 06:20 AM   #27
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The general public rarely pays for the kind of work "Jack" did or replacement parts of that standard. Which is why we have Walmart.
It is also why I do much of the work on my vehicles. If I am going to go back and redo the work done by a non-Jack, why bother with the trip. Sometimes I have to because of the nature of the work. Many times I end up taking some of the job apart. All of my vehicles have marked wheel studs and marked wheels.
Tire and wheel assemblies do get rotated to extend the wear. And I know where they are and have been.
BTW the suggestion above on using anti-seize, it is spot on. A thin coat on the hub face keeps wheel removal an easy thing. Especially for those that travel when snow and ice removal is in effect. Cleaning lug studs is another way of making sure the wheel is evenly attached to the hub.
Action
Old 10-08-2023, 09:22 AM   #28
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Hey, 40+ year auto tech here, a couple of things we did... Prepping to install new brake rotors we always cleaned the rotor as it was covered with anti-rust agent of some sort then painted the wheel bearing surface for both appearance and anti corrosion. If we had wheels off and were not replacing the rotors we had this really cool tool that was like a giant grinding wheel that we drove with one of our power tools, hollow in the center, could reface the wheel surface on the rotor in 5-10 seconds,wipe it clean and then a little shot of Wurth spray copper antiseize. Good to go. Very important here in Colorado with mag-chloride on the roads in winter. Sometimes had to beat wheels off with deadblow hammer. The grinder obviously only worked on wheels without studs which was all the euro vehicles we did. If studs then wire wheel on air grinder.
Good luck, Mark D
mrdes8 is offline   Reply With Quote
Old 10-11-2023, 09:34 AM   #29
2023 30' Globetrotter
Los Angeles , California
This is a very informative and helpful post. Sadly your first sentence sets a tone you may not have wanted. Think about that for your next post. We’re here to help each other. You can contribute without embarrassing others or upsetting them. Thank you for sharing regardless. ❤️
Mister Eff is offline   Reply With Quote
Old 10-11-2023, 10:54 AM   #30
1960 24' Tradewind
1966 30' Sovereign
Phoenix , Arizona
This is not unique to Airstream or Aluminum wheels. Most tire companies, like Discount Tire, always use a very stiff wire wheel to clean the surfaces for corrosion, rust and dirt.
dsluyk is offline   Reply With Quote
Old 10-12-2023, 04:05 AM   #31
Well, I got the two wheels off and found there was some crud on both the rims and the hubs.
I sanded off the rims with a small orbital sander and used a Dremel tool to clean up the hubs and the lugs.
I spread some anti-seize on the hubs, careful to keep it off the lugs ... FYI, a little bit of that stuff goes a long way. Good to use a Q-tip around the lugs to avoid getting it where you don't want it to go.
Hard part was getting the wheels back on! I had marked the rims to align then in the same manner as they came off (not really necessary, since I cleaned both surfaces well), but ... that did not work, as the hubs moved around as I huffed and puffed and tried to get wheels on the lugs.
Tires were made in July of this year. So, I won't have to do this again until summer of 2029.
Old 10-12-2023, 06:08 AM   #32
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Just a suggestion. I keep a flat bar pry bar under my truck seat to raise/align the trailer and truck wheels that last 1/2 inch onto the lugs.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 10-12-2023, 08:53 PM   #33
PC Conner's Avatar
2018 27' Flying Cloud
INDIAN HARBOUR BEACH , Florida
Masking Tape Lug Bolts
HINT: Masking tape the lug bolts to ensure no anti-seize gets on them.
But, the hint to use sparingly is probably just as effective.
PC Conner is offline   Reply With Quote
Old 10-14-2023, 05:08 AM   #34
Good to hear. I’ll gladly pay a “living wage” to have a job done right. Only a rich man can afford to buy it twice.
WBCCI #7180
Old 10-15-2023, 05:43 AM   #35
Great idea! Thanks ...
Old 10-15-2023, 05:44 AM   #36
Masking tape ... another great idea (should have thought of that) thanks for the tip.
Old 10-16-2023, 09:11 AM   #37
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Just screw the lug nuts back on the studs before painting with anti-seize.
Greg
greghoro is offline   Reply With Quote
Removing aluminum-forged wheels from spindle Anthony P Wheels, Hubs & Bearings 11 10-23-2022 12:57 PM
Alumimun - Forged wheels Drake1949 2016 - Current Flying Cloud 1 10-16-2019 05:26 AM
Alcoa Forged Wheels romap Wheels, Hubs & Bearings 12 04-21-2008 09:37 PM
