Old 06-23-2021, 11:54 AM   #1
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Wheel Stud R&R
A damaged wheel stud R&R is a pretty simple job. Difficult part is just removing the drum or hub.
On the bench you can use a hammer or punch and hammer to drive out the old stud from the wheel side.
To install the replacement stud, clean any debris from the hole. A small round wire brush works well.
Insert the replacement stud you might have to tap it in a bit to get it started.
Now put a flat washer or two over the threads. Thread a same size nut over the stud. In my example I used a plain lug nut note the flat side is down. Apply grease on the threads and under the nut. Use enough washers to make sure the stud it being pulled all the way thru and the nut is not just running out of threads.
Use a wrench and turn the nut down. As you tighten the nut it will pull the stud into the hub seating it. You can turn the hub over and using a punch and hammer give it a tap or two then tighten the nut again.
Remove the nut, clean off all of the old grease and install.
Make sure to correctly tighten your lug nuts to spec and recheck the lug nut torque as outlined in your manual.
Gary
ID:	398039   Click image for larger version
Name:	SETUP TO INSTALL.JPG
GCinSC2 is offline   Reply With Quote
Stripped wheel stud texascanuk Wheels, Hubs & Bearings 13 05-04-2011 07:58 PM
Broken Wheel Stud gsmithii Wheels, Hubs & Bearings 12 10-11-2010 01:09 PM
Broken wheel stud 65 Caravel kevinkatz Wheels, Hubs & Bearings 7 07-07-2009 06:31 AM
Wheel stud removal? TomW Axles 13 07-28-2004 04:42 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
