Old 03-31-2021, 08:53 PM   #1
2013 30' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
Sitting bearings
I’m thinking about buying a 2006 25 foot Safari. It has been sitting in storage for two years. My question is will the wheel bearings still be ok to run? I have to put on new tires.
jomondnv is offline   Reply With Quote
Old 03-31-2021, 09:02 PM   #2
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
My first questions is how many miles on the bearings? If very few then I would expect them to to be fine. Enjoy the new find.
bweybright is offline   Reply With Quote
Old 03-31-2021, 09:20 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Repack the bearings, and check all the brakes when you put on the new tires. This way you will know everything is good to go. Enjoy your new home on wheels!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-01-2021, 12:53 AM   #4
Sag Harbor , New York
Ditto to bweybright's question . . . mileage on bearings?
Maybe jack up each side of the trailer, using the correct jack points, and spin each wheel by hand. Listen carefully for possible "bad bearing" sounds, and observe wheel-spin true-ness, integrity etc..
If the bearings were maintained correctly . . . should be fine IMO. We had a 25' back in the 90's . . . a great length IMO.
Do you have the impression that the current owner was careful about maintenance? Service records available? Stored in the dry desert environment? Any visible rust, where there should be none?
Good luck.
Airstream sitting for 15 years... Mrcrowley Waste Systems, Tanks & Totes 17 08-18-2008 01:46 PM
Furnace sitting on plywood Sweski Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-23-2007 06:33 PM
'86 Argosy owner sitting pretty on the OH River sunflower Member Introductions 2 06-17-2006 07:55 PM
50-something sitting on axles on ground HELP?! true1977 Vintage Kin 8 07-28-2005 12:28 PM
1964 airstream sitting unmoved since 1982 mags Axles 11 05-11-2004 06:52 AM
