09-12-2018, 09:11 AM
#21
Moderator dude
1966 26' Overlander
Phoenix
Using an extension one needs to make sure the line of the extension is on the center line of the lug. Deviations from the center line can impact the torque reading.
>>>>>>>>>>>>>>Action
09-13-2018, 06:43 AM
#22
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
>>>>>>>>>>>>>>Action
Hi
True, but it's pretty tough to get very far off with a 1" extension and a 1 3/4" socket....
09-16-2018, 10:38 AM
#23
Southern
Originally Posted by Ray Eklund
.......If there is grease at the outside bottom edge of your brake drum then removing the center drum cap and pull the drum and bearing assembly off. It is not pleasant, the torque needs a cheater bar to remove the nut, and you have a snap ring that has to be removed before doing all of this......
Ray, if I understand, your bearing nut is so tight that you need a breaker bar to remove?
If so, that nut is tightened WAY too tight, and can cause early bearing failure - perhaps even a hundred miles.
After inspecting, lubing or replacing the bearings, it is important to follow the Dexter instructions for tightening. It ends up with about zero torque.
2021 M-B AMG GLE53
2011 Lance 2285 27' TT
09-16-2018, 11:14 AM
#24
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley
, Georgia
Mikapen has never dealt with the never lube bearings!!!
09-16-2018, 11:36 AM
#25
2000 25' Safari
Davidson County
, NC Highlands County, FL
Originally Posted by AnnieStrange
Attached should be a picture of one of the hubs on our 17-25' FC. We wanted to ask the forum what this might be. It looks like grease leaking out. The other three do not look like this. We want to be informed before we get it serviced. Attachment 321683
Since the only grease in that area is inside the axle/wheel bearings, I suspect bearing failure is occurring. Page 8-10 in your trailer's Owners Manual mentions this specific issue, and it refers to the Dexter manual about what to do.
You do not want to tow very much before getting it checked/repaired. If the bearing locks up and turns on the axle spindle it can ruin it and could require axle replacement.
Alan
09-16-2018, 12:48 PM
#26
Southern
Why of course I have. My comment to Ray was regarding the overtight bearing nut, which is a separate issue from the greasy wheel cap that started this thread - just making note that if the nut is too tight it can wreck the bearings and possibly the spindle or more. A breaker bar to loosen is a red flag!
Regarding the never lube bearings, as previously pointed out here, if the staining on the wheel cap is in fact grease, it's likely that somebody has used too much pressure on the Zerk when lubing, and blew out the inner seal. (Or the cleanup from a previous lube attempt was poorly done.)
That's a probable issue for the brakes, too.
As also mentioned before, it's best to remove the wheel as a first step, then perhaps the brake drum to inspect the inner seal and bearings.
Have a spare seal before you do this - they are widely available and a good thing to have in your "spare" kit.
2021 M-B AMG GLE53
09-16-2018, 01:41 PM
#27
2006 25' Safari
Howell
, Michigan
storage time
good time to check those seals and bearings and all the other items airstream
09-16-2018, 07:59 PM
#28
2016 30' Classic
Hinckley
, Ohio
Hello, your trailer has Never Lube Bearings. Dexter warranty is 3 years. The seals on the bearing has failed. It could be an easy job if your a mechanic. If not take it to any Dexter selling shop.
Do it yourself will require an outside snap ring plier. A 1 5/16 socket and a touch wrench able to reach 150 lb.
FYI Never Lube Bearings have NO grease fitting.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
09-16-2018, 08:00 PM
#29
Southern
Actually, despite my recent post, you're correct about Never Lube bearings. I was thinking Easy Lube. Thanks Mike S.
Are Never Lube bearings torqued that much tighter than regular tapered bearings?
2021 M-B AMG GLE53
09-16-2018, 08:03 PM
#30
2016 30' Classic
Hinckley
, Ohio
The spec is 145lb. If I remember correctly
09-17-2018, 09:34 AM
#31
2016 19' International
Orange County
Originally Posted by majorairhead
I just took all 4 wheels off our '19 International to have metal valve stems installed.
Which metal valve stems did you use? We purchased new Sendel Wheels and the metals ones we ordered wouldn't fit on those rims (base too wide) and had to use standard rubber ones.
