Old 04-05-2021, 10:09 AM   #1
dznf0g's Avatar
Oswego , Illinois
Nevr-Lube bearing help, please
While performing my seasonal brake, tire rotate, hub inspections, I found one nevr-lube bearing with quite a bit of play, so I am in the midst of replacing. It appears that it is frozen on the spindle. I've used PB Blaster and a pneumatic air hammer.
Is there something I am missing? I am not sure I can effectively get heat where it need to be.
ID:	392471   Click image for larger version
-Rich-
Old 04-05-2021, 10:48 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Hi Rich...
Do I see a concave fitting to center a puller?
Still not moving?
Old 04-05-2021, 10:57 AM   #3
dznf0g's Avatar
Oswego , Illinois
Nope, have a puller on as we speak. Tried heat as well.
-Rich-
Old 04-05-2021, 11:37 AM   #4
What I have done...tighten the puller, heat with an industrial heat gun, leave it heating the hub, return and tighten the puller and re-whack the hub. Repeat.
Acetylene may be in your future... 🤨
Old 04-05-2021, 12:03 PM   #5
2014 27' FB International
Lewisville , Texas
Anti-Seize
From Dexter’s Nev-R-Lube Drums/Bearings instructions:
"Clean and inspect spindle shaft. Apply a light coating of anti-seize Lubricant to the spindle shaft prior to assembling drum"
When I pulled one of my drums to inspect the brakes, I missed this step. The next day I was making some notes and saw the above in the instructions.
I went ahead and pulled the drum again to apply the Anti-Seize. Just wanted to remind you, just in case, it might help avoid this in the future.
NO NOIZE is offline   Reply With Quote
Old 04-05-2021, 12:14 PM   #6
dznf0g's Avatar
Oswego , Illinois
Originally Posted by NO NOIZE View Post
From Dexterís Nev-R-Lube Drums/Bearings instructions:
Yup, thanks...I have been cursing Dexter for no using anti-seize at assembly.
-Rich-
Old 04-05-2021, 12:16 PM   #7
dznf0g's Avatar
Oswego , Illinois
I don't think heating the hub will help. I need the inner race to expand on the spindle.
-Rich-
Old 04-05-2021, 12:32 PM   #8
Lewisville , Texas
Penetrating Oil
Everyone has a favorite penetrating oil, usually the one I have on hand at the time. I have used PB, Liquid Wrench, Seafoam Deep Creep, Break Free, WD-40 and Kroil. Some swear by Kroil, don't know if it would help, might be worth a try.
https://www.amazon.com/Kano-Kroil-Pe...e%2C362&sr=1-1
Although, Kroil came out last in this test:
Good luck!
Old 04-05-2021, 01:26 PM   #9
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Personally, I’ve never had anything but stellar results when using Corrosion X. Didn’t break one bolt changing out my original suspension on my ‘64 Silver Streak for example...
Ian
Iansk is offline   Reply With Quote
Old 04-05-2021, 01:39 PM   #10
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Rich,
This video may help. It looks like your large snap ring was still in place.
Hope this helps.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 04-05-2021, 01:42 PM   #11
dznf0g's Avatar
Oswego , Illinois
Originally Posted by DaveP View Post
Rich,
Hope this helps.
That snap ring holds the bearing in the hub, not the bearing to the spindle
-Rich-
Old 04-05-2021, 01:58 PM   #12
2018 30' Flying Cloud
Springfield , Ohio
Looks like you've been doing it wrong. You need a really large pair of snap ring pliers for the job. I use the pliers in the link below. They are reasonably priced and will do the job safely.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 04-05-2021, 02:08 PM   #13
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
What Rich said.
Sorry itís going into extra innings on R&R.
And this is the puller tool that Iíd grab if facing Nev-R-lube bearing replacement. Iíve used same on my VW front wheel cartridge bearing.
https://www.harborfreight.com/front-...-pc-63728.html
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-05-2021, 02:17 PM   #14
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Originally Posted by GCinSC2 View Post
What Rich said.
This bearing tool is for changing out the bearing "Once" the hub is removed, the OP is having trouble sliding the bearing/drum assembly off the Spindle.
When we have trouble getting rear drums off of a Ford Focus (similar style) we oder a new bearing and use a HD 3 Jaw puller,
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Old 04-05-2021, 02:46 PM   #15
Hi Rich...
Feel like getting another tool?🥴
Old 04-05-2021, 02:52 PM   #16
Lewisville , Texas
Hi Rich...
That is pretty cool
Old 04-05-2021, 03:07 PM   #17
dznf0g's Avatar
Oswego , Illinois
Hmmm, I wonder....my 3 jaw isn't getting it. I'm gonna soak and pound for a bit. That's a lot of surface area to penetrate though. Cant get to the backside.
-Rich-
Old 04-05-2021, 03:14 PM   #18
GCinSC2's Avatar
Rich
Wonder if you can rent a stout hub puller from favorite auto parts store that uses the hub studs to attach puller flange and has a bigger forcing screw?
Good luck
Gary
S/OS #001
Old 04-05-2021, 03:19 PM   #19
dznf0g's Avatar
Oswego , Illinois
Rich
Good luck
Gary
Well, mine is rated at 5k pounds. Are there bigger ones? Other than that hydraulic one above?
-Rich-
Old 04-05-2021, 03:41 PM   #20
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
Hi Rich...
Ooooo..... the parts I could ruin w/ such.... turning a maintenance job into a large-scale rebuild....
-Leslie
LNBright is offline   Reply With Quote
Drum Brake inspection on Nevr-Lube axles steverino Brakes & Brake Controllers 2 04-19-2018 09:26 AM
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 11 10-09-2017 09:06 PM
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
Nevr-Dull polish? Deluxe21 Cleaning, Stripping & Polishing 8 06-30-2010 10:28 PM
