05-27-2020, 10:48 PM
Corona
Lug nut size
Anyone know the size of lug nuts the new Caravel has? Can’t get my regular car star into the small spaces of the Caravels wheels to find out. Need to torque the wheels. Any help is MUCH appreciated.
05-27-2020, 11:11 PM
2006 34' Classic S/O
1994 28' Excella
1950 19' Globetrotter
Elgin
Hard to say. Get a socket set out on the nuts and trial fit them. Both SAE & Metric.
Then get a dedicated tire iron (4X cross type) that matches your socket "best fit" to make break them. Keep it with the trailer at all times.
Then get the correct deep socket and a short extension bar to use with your torque wrench to apply the correct torque.
All The Best...
'Ol Bob
06-04-2020, 02:16 PM
2020 16' Caravel
Garland
Works for me. Not sure about your Caravel?
CRAFTSMAN Shallow Socket, SAE, 1/2-Inch Drive, 13/16-Inch, 12-Point (CMMT47511), also a 22MM might work.
Eddie
Cosmic Turtle
2017 Tacoma
11-18-2020, 01:57 PM
2021 16' Caravel
2022 23' Globetrotter
Callao
, Virginia
BullSharkLA1, did you find out what size the lug nuts were? I'm picking up a 2021 Caravel 16RB soon and would like to be prepared.
12-02-2020, 08:38 AM
2021 20' Caravel
Indianapolis
, Indiana
Did you find out what size the lug nuts are on your Caravel? I'll be picking mine up in a couple of months. thanks
12-03-2020, 06:52 AM
2021 16' Caravel
Callao
, Virginia
See the thread at https://www.airforums.com/forums/f54...rb-216955.html
for more information but, bottom line, I called Aitrstream, they said 3/4”, I got a 3/4” thin walled 6 point socket and will pick up our 2021 Caravel 16RB next Tuesday. Will post whether the socket fits.
12-03-2020, 07:03 AM
Evergreen
I don't know about the Caravel, but my 2020 International has 13/16" lugs. My Airstream dealer told me that it was 3/4", but he was wrong. I bought a 6-point socket at Home Depot that works well.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
12-03-2020, 08:06 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Lug nuts are 1/2" diameter with 20 threads per inch. Lug nut size is given in this Parts Book on page II-2.
https://www.airstream.com/wp-content...Parts-Book.pdf
Lug nuts on each of the several Airstream trailers I've owned were this size. On all of them I used a 13/16" six point deep socket, that is until the thin chrome sheet metal nut cap came off. If the trailers still come with nut caps you might consider changing to lug nuts without a cap. When the cap comes off/loose a different size lug wrench and other tools are needed.
This can be a problem when a flat tire happens while traveling, when the cap spins and the lug nut does not. The only way to remove the spinning nut cap is to cut it off.
Alan
12-04-2020, 09:50 AM
2021 16' Caravel
Callao
, Virginia
Thanks, A W Warn, for the referral to the parts book; that will be a fantastic resource! We're picking up our Caravel 16RB on Tuesday. This forum has been a wonderful source of information to help us prepare.
12-04-2020, 04:05 PM
2000 25' Safari
Davidson County
This is an excellent source for manuals and other useful documents>
https://www.airstream.com/owners/
Alan
