Old 10-31-2020, 03:01 PM   #1
Dallas , Texas
Looking for bearing seal
Hi All,
I am in the process of renovating a 1963 overlander. The shell is currently off and the frame is at a shop getting the torsion axles, bearings, brakes, all that fun stuff checked out. BUT we ran into a hiccup and cannot find the correct size bearing seals to replace the original ones.
I ordered a seal that I thought was going to work (just a little wider than original) but it actually ended up not being snug enough. It went in too easy.
I have called around to all my local automotive, bearing and trailer shops to see if anyone caries that size, but no luck. Does anyone know where I can find that size bearing seal or have any advice?
My original seal number:
NATIONAL 292100
Measurements:
OD 3.26
ID 2.26
Width .31
Thanks in advance!!
-Lauren
Lauren b is offline   Reply With Quote
Old 10-31-2020, 04:16 PM   #2
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I'll bet Out of Doors Mart can help. Give them a call.
http://odmrv.com/catalog/index.php?m...rd=grease+seal
Alan
Old 10-31-2020, 04:40 PM   #3
Kevin245's Avatar
Take the old seal to your nearest NAPA. They should be able to cross reference a replacement seal for you.
William C. Swinney
Kevin245 is online now   Reply With Quote
Old 10-31-2020, 04:49 PM   #4
Dallas , Texas
I will call Out of Doors Mart and see if they can find it.
Kevin- Napa tried and couldnít find the correct one. They ordered me one, but it was just a little off.
Old 10-31-2020, 05:08 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
Some info:
https://www.airforums.com/forums/f43...ari-46487.html
CRH is offline   Reply With Quote
Old 10-31-2020, 05:12 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
Make sure it's a double lip seal.
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 10-31-2020, 06:09 PM   #7
A W Warn's Avatar
2000 25' Safari
NATIONAL 292100
Measurements:
OD 3.26
ID 2.26
Width .31
Thanks in advance!!
-Lauren
If you can find a sale source, try Dichtomatik Seal 223263TB.
2.250 ID
3.264 OD
0.312 W
Not exact but I think will work.
Alan
Old 11-01-2020, 01:22 PM   #8
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Don’t call GO to Napa they can help
bibbs is offline   Reply With Quote
Old 11-01-2020, 04:27 PM   #9
Dallas , Texas
I ordered seal # 223263TB
Iíll updated if they work or not. Thanks for all the help!
Old 11-01-2020, 04:57 PM   #10
That should be the double lip seal.
Tahawus
RLC
Wheel bearing & seal specs for 2005 Classic 30' Wingeezer 2001 - 2005 Classic 3 12-12-2016 12:47 PM
Bearing Buddy Bearing Protectors Ron A Wheels, Hubs & Bearings 23 05-19-2015 06:48 AM
Need Bearing Seal Part Number for 2000 30' Excella Cracker Wheels, Hubs & Bearings 3 06-09-2008 06:19 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
Brake shoes and bearing seal source needed. sfixx All Argosy Trailers 2 11-23-2004 04:25 PM
