Old 07-01-2023, 12:03 AM   #1
2021 22' Caravel
Bellevue , WA
Left side lug nuts are hot
Hi, the left (driver's side) lug nuts of my 2021 22-FB Carvel are hot. On top of that, the trailer is making odd noises. The right side is fine. Neither tire is hot. Can I assume that the bearings are shot?
John
John Spilker is offline   Reply With Quote
Old 07-01-2023, 12:26 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
You could have brake shoes that are adjusted too tight on the left side.
CRH is offline   Reply With Quote
Old 07-01-2023, 06:16 AM   #3
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
Don't assume anything, have a look. Inspect the brakes and bearings. They need to be right or the result will be bad.
Aironius is offline   Reply With Quote
Old 07-02-2023, 01:44 PM   #4
2017 25' International
West Lake Hills , Texas
Loose guts of the brake rattling around inside the drum is a common problem. Jack up the driver side and spin the wheel. If you feel a lot of resistance or hear clattering then the brake needs work. If moderately handy you can do the work yourself. You may need to pull the drum to make sure and it has to be removed to replace the brake assembly. Sometimes when towing very slowly you can hear the racket.
Fungus is offline   Reply With Quote
Old 07-02-2023, 05:49 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I would not tow your trailer until you diagnose and repair the cause of the hot hub. If you don't want to do the job, you might be able to call a mobile RV tech. Repairing trailer electric brakes is a trailer industry common component and not exclusive to Airstream. Axles, brake assemblies, brake drums, bearings, seals are all common components, just like tires. Any trailer shop should be able to do it. Just notify the tech where the correct jacking points are on the trailer. Your manual explains the location.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 07-05-2023, 03:56 PM   #6
2021 22' Caravel
Bellevue , WA
Quick update
Coachnet will have the trailer hauled to the dealer on Friday. Given the left wheel is making noise, I didn't want to tow the trailer some 25 miles, mostly on the thruway.
I have no idea what expenses we face. I found out that the Dexter Nev-R-Lube bearing warranty is 2 years for parts and service. We've owned the trailer for 2 years and 5 days at the time we reported the problem. I don't know if the wheel has suffered other damage. I doubt we have put on more than 8,000 miles on the trailer.
When the bearing problem occurred, we were just returning from a trip along the Oregon and Washington coast. We had the water pump go out as well as the inverter. Fortunately, both problems were loose connections that I was able to fix.
I can't say how bummed out I am about this bearing issue, but I guess that's life.
Old 02-20-2024, 04:17 PM   #7
2021 22' Caravel
Bellevue , WA
Another update. It turns out that the bearings were gone. Airstream picked up the tab even though the warranty had expired. Dexter had also promised to pick up some, if not all, the costs but I preferred to work through Airstream. So the story had a happy ending.
Old 02-20-2024, 04:45 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Thanks for the update. Glad both are willing to step up. Even if Dexter picks up all the bill they would just have you get an authorized dealer (such as an Airstream dealer) do the work. Just be happy you don't have to pay.
Old 02-20-2024, 04:51 PM   #9
2017 28' International
Jim Falls , Wisconsin
This is one of the reasons to have a TPMS system. I had a brake go bad on one of my tires. Would never really had known about it, but the alarm went off. Thankfully, I was close to a trailer repair place. Was able to get it fixed fairly quickly.
Daquenzer is offline   Reply With Quote
Old 02-20-2024, 06:09 PM   #10
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I also have a trailer TPMS with tire temperature being monitored also. Truck drivers swear by such systems. A blown tire under our Airstreams can do major damage to the trailer. I was always reading tire pressures before I pulled away with my Airstream. But heck, I could run over a nail in the next mile down the road. My TPMS will alert me of low pressure before the tire blows apart.
I think a TPMS for our Airstreams is a good investment in safety.
David
Old 02-21-2024, 09:28 AM   #11
2021 22' Caravel
Bellevue , WA
Thanks. That is a great idea and I will look into it.
McGard Lug Nuts @ Lock nuts PSU1981 Wheels, Hubs & Bearings 1 12-13-2018 07:13 PM
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 09:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts sepezlover Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
