I'm going to pick up a 1980 31. Does anyone know the part # for the inner wheel bearing seals. I am going to repack the bearings before pulling it 500 miles. I am picking it up on a weekend so I may not be able to find some then.
I have been online trying to find the same thing. we have an 2002, 34. From the replies I see and researching it, the best number, most often replied to, was Dexter 010-036-00. Redline Trailer Supply's number was RG06-070, National parts is 440265560. They are all double lipped and same exact size.
Outside diameter 3.376 Inside 2,25
I've got 4 wheels with allmost new tires. And two older spares. So tires are covered. Also taking a set of lights to set on the back bumper. I made a 50 ft set with a50 ' extension cord when I was helping a friend move trailers he bought and sold.
call this company to make sure. 800 453 7379. It says after 1998 for these parts number but I have also seen where they fit 1980 and newer. Thes were the cheapest price we found.
DEXTER 2.25" ID Grease Seal #010-036-00
Our Price: $4.64
Rating: 4.25 - 4 Review(s) | Add Your Review
Seal I.D. = 2.25" O.D. = 3.371"
Metal body construction with Double-Lip rubber seal.
Fits Dexter 12" x 2" Hubs / Drums (after 1998). Used with 1-3/4" ID wheel bearings (25580).
GREASE SEALS should be inspected frequently and replaced if they show signs of wear such as excess grease build up on the inside of wheel hub or trailer rim. Hub grease seals help prevent water and dirt from entering the hubs providing protection against bearing failure.
